Chordata_notochord_v0_1_1b.tar.gzHub program of the Chordata open source motion capture system.0.1.1b Changelog: ========= - "Scan" feature - Fix bug with acelerometer and gyroscope calibration - Validate acel and gyro calibration - Improve calibration CLI UX - Add higher Sensor data rate (experimental) gzip - 844.67 kB - 05/21/2019 at 16:28 |
Chordata_BOM_R2-2_2019_02_4.pdfComplete bill of materialsAdobe Portable Document Format - 223.90 kB - 02/12/2019 at 13:34 |
Chordata-K_ceptor-R2.2.zipSensing hardware of the Chordata open source motion capture system.KICAD project Zip Archive - 100.77 kB - 02/12/2019 at 13:16 |
Chordata-Hub-R1.2.zipHub hardware of the Chordata open source motion capture system.KICAD project Zip Archive - 142.84 kB - 02/12/2019 at 13:16 |
Chordata_blender_client_v0_1_0a.zipBlender add-on allows you to receive, record, and retransmit physical motion capture data coming from a Chordata open source motion capture systemZip Archive - 12.59 MB - 10/27/2018 at 10:59 |
2018_10_21-Chordata Technical documentation.pdfA detailed description of how the Chordata system is implemented. It contains: parts specifications, functional diagrams, schematics, protocol descriptions, power considerations, and more.All this content can also be found on the "How it works" section of the Chordata wiki: http://wiki.chordata.cc/wiki/How_it_works Adobe Portable Document Format - 1.64 MB - 10/21/2018 at 10:24 |
3D printable K-Ceptor socket.zipSTL and BLEND files for 3D-printable K-Ceptor socket.It can be used to fix the sensing units to the performer's body. more info at http://wiki.chordata.cc/wiki/User_Manual/1._Chordata_parts/1.3._Sensor_Fixings Zip Archive - 362.08 kB - 10/18/2018 at 09:48 |
Chordata_notochord_v0_1_0a.tar.gzHub program of the Chordata open source motion capture systemgzip - 2.23 MB - 08/22/2018 at 19:22 |
Chordata_KCeptor_R2.zipSensing hardware of the Chordata open source motion capture system.KICAD project Zip Archive - 102.48 kB - 08/22/2018 at 19:22 |
Chordata_id_module_R2.zipID plugin for the KCeptor units of the Chordata open source motion capture system.KICAD project Zip Archive - 7.87 kB - 08/22/2018 at 19:22 |
Chordata_Hub_R1.zipHub hardware of the Chordata open source motion capture system.KICAD project Zip Archive - 145.81 kB - 08/22/2018 at 19:22 |
IMU Proto - EAGLE and GERBER.zipSource and gerber files for the IMU-Proto board based on a LSM9DS0 sensor and a PCA9544A i2c multiplexerZip Archive - 148.65 kB - 09/29/2017 at 08:55 |
