trying to invert dektop-plotter to build an infinty-plotter-bot
1st wheel test...
View all 3 project logs
Okay I see you may be talking about a robot plotter (or tortoise) rather than plotting infinity.
yep, now you are right... Just changed the headline to avoid more confiusion
Poincare's disk is a circle that plots an infinite distance.You may know it from Escher's work (see http//mathworld.wolfram.com/images/eps-gif/HyperbolicTessellation_1000.gif).
"Poincare" disk?
?what do you mean?
DoctorDre
Henrik Sorensen
Victoria
Shree Suresh
Yes, delete it Cancel
You are about to report the project "Omni wheel Infinity plotter", please tell us the reason.
