This board is part of Fyber Labs Flex Module project.
We are utilizing a generally available JST connector that supports multiple amps. We chose the 4 pin version as it will easily accommodate common 3 lead 5V RGB LED strips as well as the 4 pin versions. With some 4 pin strips this adds the ability to split and splice the strips in multiple directions using simple connectors. We will be discussing this further in the Dance Kit demo project.
Any software related will be released under BSD or MIT license. SAAS or cloud based software will be AGPL.
