LEDs are so pretty. I wonder if this is some sort or primal instinct based on the safety from predators of being near fire.
It doesn't start stepping through my test pattern after soldering, so I'll try reprogramming, or explicitly stating some of the new port directions.
Maybe it shook some of the bits loose.
