I2C Encoder V2 will come soon!
04/08/2018 at 21:21 • 0 commentsWe are currently working on the second version of this board.
Here there are more details: https://hackaday.io/project/122039-i2c-encoder-v2
New HW release!
11/22/2017 at 22:57 • 0 commentsFirst of all this product is on sale on Tindie !
Second, i made a new HW release with the I2C pull-up issue resolved.![]()
For resolving the problem i just split the P-UP jumper in two.
I already update the documentation on GitHub.I also made a very useful bed of nails for programming and testing the boards.
For the testing purpose i used an Arduino board that simulate the encoder rotation, the address jumpers and check the LED voltage.
I2C pull-up issue
10/22/2017 at 09:38 • 0 commentsThanks to the community i found a problem on the i2c pull-up resistor.
When the P-UP jumper is open, the two resistors are in parallel to the SCL and SDA pins, which causes problem on the bus.
The solution is simply remove them when pull-up resistors are not used.![]()
My appreciations to the hackaday community!
GitHub repository and Tindie insertion
10/21/2017 at 16:02 • 0 comments
Saimon
