1Github Repository
Get source code, PCB files and documentation at https://github.com/roboberimbau/berimbau.
2Build and Upload
Build Dependencies
- avr-gcc (>= 4.9)
- avrdude
- make
Installing the AVR GCC Tool Chain
GNU/Linux
Ubuntu (16.04)
$ sudo apt install make avr-libc avrdude binutils-avr gcc-avr
Arch Linux
$ sudo pacman -S avr-gcc avr-binutils make avr-libc avrdude
Remember to give the current user permissions to access serial ports (on Ubuntu and derivatives you need to include the user in the dialout group, on Arch Linux the group is called uucp). Don't forget to logout and login to update the user permissions.
MacOS
The required dependencies can be installed through the homebrew package manager.
$ brew tap osx-cross/avr $ brew install avr-libc avr-gcc avr-binutils avrdude
Windows
Download the complete AVR Tool Chain compiled for Windows. Extract the compressed file into "C:\Program Files". Add the "C:\Program Files\avr8-gnu-toolchain\bin" directory to the PATH environment variable.
How to build and upload
Open a terminal and navigate to the cloned repository directory. Then execute the
make
command to compile the source code. To upload you need to issue the "make burn PGPORT=xxx" where 'xxx' is the serial port name where the Arduino UNO is connected (on Linux it's typically /dev/ttyACMx or /dev/ttyUSBx, on macOS it will have different names depending on the USB to Serial bridge used, but is typically /dev/tty.usbmodemxxxx, on Windows it will be a COMx, where 'x' varies from 1 to 9).
