I finally finished writing the bouncing ball tutorial, and published the documentation. You can see it at http://ugame.readthedocs.io/en/latest/tutorial.html
It merely scratches the surface — I will need more documentation, in particular, I will need topic guides explaining some of the most useful techniques for writing the games. But this is at least a start.
could you add the screw hole dimensions and distances etc? looking into printing something myself, once the 2nd battery is here. The first one came puffed (maybe due to weather)..
I could publish an OpenScad model, I suppose? Would that help?
I just wanna know where to put what screw size :) Seems like a 2.5mm hole.
The hole is exactly 2.6mm in diameter, so M2.5 should work.
Added here: https://github.com/python-ugame/ugame-10-hardware/blob/master/ugame-10.scad
