I finally finished writing the bouncing ball tutorial, and published the documentation. You can see it at http://ugame.readthedocs.io/en/latest/tutorial.html
It merely scratches the surface — I will need more documentation, in particular, I will need topic guides explaining some of the most useful techniques for writing the games. But this is at least a start.
deʃhipu
could you add the screw hole dimensions and distances etc? looking into printing something myself, once the 2nd battery is here. The first one came puffed (maybe due to weather)..
I could publish an OpenScad model, I suppose? Would that help?
I just wanna know where to put what screw size :) Seems like a 2.5mm hole.
The hole is exactly 2.6mm in diameter, so M2.5 should work.
Added here: https://github.com/python-ugame/ugame-10-hardware/blob/master/ugame-10.scad
