5Coding
int note_C = 2; int note_D = 3; int note_E = 4; int note_F = 5; int note_G = 6; int note_A = 7; int note_B = 8; int note_Ca = 9; int sound = 10; int buttonstate_C = 0; int buttonstate_D = 0; int buttonstate_E = 0; int buttonstate_F = 0; int buttonstate_G = 0; int buttonstate_A = 0; int buttonstate_B = 0; int buttonstate_Ca = 0; int tones[] = { 1915, 1700, 1519, 1432, 1275, 1136, 1014, 956 }; //freq int toner = 0; void setup() { pinMode(note_C, INPUT); pinMode(note_D, INPUT); pinMode(note_E, INPUT); pinMode(note_F, INPUT); pinMode(note_G, INPUT); pinMode(note_A, INPUT); pinMode(note_B, INPUT); pinMode(note_Ca, INPUT); pinMode(sound, OUTPUT); } void loop() { buttonstate_C = digitalRead(note_C); buttonstate_D = digitalRead(note_D); buttonstate_E = digitalRead(note_E); buttonstate_F = digitalRead(note_F); buttonstate_G = digitalRead(note_G); buttonstate_A = digitalRead(note_A); buttonstate_B = digitalRead(note_B); buttonstate_Ca = digitalRead(note_Ca); if((buttonstate_C == LOW) || (buttonstate_E == LOW) || (buttonstate_G == LOW) || (buttonstate_D == LOW) || (buttonstate_F == LOW) || (buttonstate_A == LOW) || (buttonstate_B == LOW) || (buttonstate_Ca == LOW) ) { if (buttonstate_C == LOW) { toner = tones[0]; } if (buttonstate_D == LOW) { toner = tones[1]; } if (buttonstate_E == LOW) { toner = tones[2]; } if (buttonstate_F == LOW) { toner = tones[3]; } if (buttonstate_G == LOW) { toner = tones[4]; } if (buttonstate_A == LOW) { toner = tones[5]; } if (buttonstate_B == LOW) { toner = tones[6]; } if (buttonstate_Ca == LOW) { toner = tones[7]; } digitalWrite(sound, LOW); delayMicroseconds(toner); digitalWrite(sound, HIGH); delayMicroseconds(toner); } else //in case no button is pressed , close the piezo { digitalWrite(sound, HIGH); } }I hope you like my tutorial on this laser piano. Subscribe to my YouTube channel for more tutorials like this.
My Social Profile Links:
vivek gupta
