Propeller Development Board
Simple Parallax Propeller development board.
This is my own version of a Parallax Propeller development board.
Uses a PIC microcontroller for the USB-Serial interface, can be powered from either USB or a dedicated power source, includes an EEPROM to store the program and data, and provides a 2x20 pin header exposing all 32 I/O pins from the Propeller microcontroller, power and control lines.
Compatible with all standard Propeller development tools.
  • 2 × Resistor 4.700 ohm 1/4 watt
  • 3 × Resistor 220 ohm 1/4 watt
  • 1 × 24LC512 Memory ICs / EEPROMs
  • 1 × PIC18F14K50 Microprocessors, Microcontrollers, DSPs / Microcontrollers (MCUs)
  • 1 × LM1117T-3.3 Power Management ICs / Linear Voltage Regulators and LDOs
View all 19 components
