1Grove Connection on UART'2' and BeagleBone Green
Just stick the grove connector to the GPS w/ grove connector into the right grove connector on the BBG (beaglebone green). UART2!
config-pin p9.21 uart && config-pin p9.22 uart
That command will give you the access to UART2!
Then...
2Add the given source to your distro on the BBG...
Hello,
Please forgive me. For some reason the Python and Python3 exchange has not worked to my liking. I am going to go back to regular Python if you still run Buster and not Bullseye.
import serial import Adafruit_BBIO.UART as UART from time import sleep UART.setup("UART2") ser=serial.Serial("/dev/ttyS2", 9600) class GPS: def __init__(self): # This sets up variables for useful commands. # This set is used to set the rate the GPS reports UPDATE_10_sec = "$PMTK220,10000*2F\r\n" # Update Every 10 Seconds UPDATE_5_sec = "$PMTK220,5000*1B\r\n" # Update Every 5 Seconds UPDATE_1_sec = "$PMTK220,1000*1F\r\n" # Update Every One Second UPDATE_200_msec = "$PMTK220,200*2C\r\n" # Update Every 200 Milliseconds # This set is used to set the rate the GPS takes measurements MEAS_10_sec = "$PMTK300,10000,0,0,0,0*2C\r\n" # Measure every 10 seconds MEAS_5_sec = "$PMTK300,5000,0,0,0,0*18\r\n" # Measure every 5 seconds MEAS_1_sec = "$PMTK300,1000,0,0,0,0*1C\r\n" # Measure once a second MEAS_200_msec = "$PMTK300,200,0,0,0,0*2F\r\n" # Meaure 5 times a seconds # Set the Baud Rate of GPS # BAUD_57600 = (b"$PMTK251,57600*2C\r\n") # Set Baud Rate at 57600 BAUD_9600 = "$PMTK251,9600*17\r\n" # Set 9600 Baud Rate #Commands for which NMEA Sentences are sent ser.write(BAUD_9600) sleep(1) ser.baudrate = 9600 GPRMC_ONLY = "$PMTK314,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0*29\r\n" # Send only the GPRMC Sentence GPRMC_GPGGA = "$PMTK314,0,1,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0*28\r\n" # Send GPRMC AND GPGGA Sentences SEND_ALL = "$PMTK314,1,1,1,1,1,1,0,0,0,0,0,0,0,0,0,0,0,0,0*28\r\n" # Send All Sentences SEND_NOTHING = "$PMTK314,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0*28\r\n" # Send Nothing ser.write(UPDATE_1_sec) sleep(1) ser.write(MEAS_1_sec) sleep(1) ser.write(GPRMC_GPGGA) sleep(1) ser.flushInput() ser.flushInput() def read(self): ser.flushInput() ser.flushInput() while ser.inWaiting() == 0: pass self.NMEA1=ser.readline() while ser.inWaiting() == 0: pass self.NMEA2 = ser.readline() NMEA1_array = self.NMEA1.split(',') NMEA2_array = self.NMEA2.split(',') if NMEA1_array[0]=='$GPRMC': self.timeUTC = NMEA1_array[1][:-8] + ':' + NMEA1_array[1][-8:-6] + ':' + NMEA1_array[1][-6:-4] self.latDeg = NMEA1_array[3][:-7] self.latMin = NMEA1_array[3][-7:] self.latHem = NMEA1_array[4] self.lonDeg = NMEA1_array[5][:-7] self.lonMin = NMEA1_array[5][-7:] self.lonHem = NMEA1_array[6] self.knots = NMEA1_array[7] if NMEA1_array[0] == '$GPGGA': self.fix = NMEA1_array[6] self.altitude = NMEA1_array[9] self.sats = NMEA1_array[7] if NMEA2_array[0] == '$GPRMC': self.timeUTC = NMEA2_array[1][:-8] + ':' + NMEA1_array[1][-8:-6] + ':' + NMEA1_array[1][-6:-4] self.latDeg = NMEA2_array[3][:-7] self.latMin = NMEA2_array[3][-7:] self.latHem = NMEA2_array[4] self.lonDeg = NMEA2_array[5][:-7] self.lonMin = NMEA2_array[5][-7:] self.lonHem = NMEA2_array[6] self.knots = NMEA2_array[7] if NMEA2_array[0] == '$GPGGA': self.fix = NMEA2_array[6] self.altitude = NMEA2_array[9] self.sats = NMEA2_array[7] myGPS=GPS() GPSdata=open('/GPS_data/GPS.txt', 'w') # write the file but first make sure it is located in the GPS_data dir. GPSdata.close() while(1): myGPS.read() if myGPS.fix != 0: try: latDec = float(myGPS.latDeg) + float(myGPS.latMin)/60. lonDec = float(myGPS.lonDeg) + float(myGPS.lonMin)/60. if myGPS.lonHem == 'W': lonDec = (-1)*lonDec if myGPS.latHem == 'S': latDec = (-1)*latDec alt = myGPS.altitude GPSdata = open('/GPS_data/GPS.txt', 'a') # append the writen file GPS.txt in the GPS_data directory... myString = str(lonDec) + ',' + str(latDec) + ',' + alt + ' ' GPSdata.write(myString) GPSdata.close() except: passThis is the update to Python3 but for some reason, it is not running right now. I will get closer to the window or go outside to run the GPS module to keep testing. Sorry for the conclusive evidence. It seems that on Python3, there are many changes that affect the output of bytes and strings.
