Research #1 - Possible Metal/Alloy for construction of Mazinger Z
10/18/2017 at 12:49 • 0 commentsgmSo, I've narrowed down the already existing metal alloys which could be used to build Mazinger Z. The possible alloys I have chosen are, Depleted Uranium Alloy, Magnesium, New Magnesium based alloy, Scandium and/or Nitinol (Nickel Titanium). However, one day I shall intent to create a material as strong as Super Alloy Z. Here are some images of what the alloys look like and what they are used for:
Nitinol (Nickel Titanium):
![Super-Elastic needle Super-Elastic needle]()
Scandium (Lightweight and has a very high melting point):![]()
Scandium
Magnesium:![Image result for magnesium Image result for magnesium]()
Magnesium ![Image result for aircraft engine Image result for aircraft engine]()
Aircraft Engine
Depleted Uranium Alloy:![Image result for depleted uranium alloy Image result for depleted uranium alloy]()
DU penetrator from the PGU-14/B incendiary 30mm round ![]()
U.S. Tank
New Magnesium based alloy, (light as lithium, strong as titanium)(it has an exceptional strength and is extremely lightweight is made of 86% of magnesium, and 14% of silicon carbide particles):![]()
