I'm implementing logic that takes as an input a voltage vector in space vector space, and outputs values that the pwm timers use to generate the inverter gate drive logic. I'm using Vivado-HLS to do this. I've written some code, C code! Eventually Vivado-HLS will turn that code into Verilog, but the first step is to create a test that runs on-laptop to verify that the C code to be transformed actually behaves the way it should before synthesizing Verilog from C. Here's the current output from the test:
When this is working as it should, it will look like three sinusoids spaced with 120 degree phase angle, not like three winking skeletons.
It looks more like dancing bunnies to me.
Looks like a couple offsets and a multiply and you'll be there. 3 bugs, maybe 4.
