I printed the mount, made the tiny board.
Then I used a hot glue gun to glue the board onto the mount. And then held the reed switch in place with tape whilst soldering it onto the board.
3D printed mount for reed switch, to connect my itron gas meter to the loxone home automation system
GasMeterPulseCounter.stl3D model for printingStandard Tesselated Geometry - 31.82 kB - 10/20/2017 at 22:32 |
GasMeterPulseCounter.skpSketchup 3D modelSSEYO Koan Play File - 76.26 kB - 10/20/2017 at 22:32 |
For using the pulse counter with loxone- to convert the m3 gas into kWh that loxone uses, I use a conversion factor of 9.184 as shown- I think this gives reasonable accuracy.
