Initial Question:
What can we do to top being rick rolled by SpriteTM
Initial Concept that stuck 3D SLA Printer.
Badge Github Repo:
https://github.com/JacobChrist/HaD-Super-Con-2017-Badge-Hacking-SLA-3D-Printer
Portable super small low cost 3D SLA printer with a 30mm^3 print volume.
Initial Question:
Badge Github Repo:
Cover Unoptimized.svgThis is a first cut of a file to be used to cut the cover on Ponoko. This file should not be used to make the cover, it needs clean up, but its a place holder. To use this file the stroke width need to be set to 0.01mm and the fill needs to be removed.svg+xml - 640.54 kB - 10/22/2017 at 19:56 |
Modified Coupler and Rod.jpg1/4 20 threaded rod with a flat ground on one end. 1/4 20 coupling nut with taped holes for set screwsJPEG Image - 48.29 kB - 10/22/2017 at 14:53 |
We spent $700 to win $256, money well spent. Thanks Hackaday!
Just arrived to HaD Super Con and finally can fit check the badge.
So it turns out that this is not just a super tiny SLA printer, but it a HaD badge hack super tiny SLA printer.
Jacob: Printed base overnight. I thought it was going to be difficult to get off the print bed but it was actually quite easy. Assembled and fit check all the pieces. Need to reprint the coupler to avoid interference with display board.
Need to cut the lead screw and mount the build plate. Going to turn the machine over to Mike to complete these tasks.
Jacob: Printed pillow block and sensor mount today, base design is almost complete, hope to kick off a print tonight.
Michael: Built light cover and build chamber (and build chamber lid). Cut guide rods to length. Tested linear slide with test pieces along with a PONTECH STP300.
Hackaday.io component list leaves something to be desired so we put the BOM into Google Doc's:
Brilliant ! Keep the updates coming on how this shapes up
