Badge Hacking Ceremony
11/15/2017 at 03:21 • 1 commentWe spent $700 to win $256, money well spent. Thanks Hackaday!
Mommy, Daddy?
11/15/2017 at 02:45 • 1 comment![]()
HaD Super Con Day 2 VLog 3 - 6
11/12/2017 at 07:41 • 0 comments -
HaD Super Con Day 2 VLog 2
11/12/2017 at 01:00 • 0 comments -
HaD Super Con Day 2 VLog 1
11/11/2017 at 19:12 • 0 comments -
We have arrived
11/10/2017 at 22:02 • 0 commentsJust arrived to HaD Super Con and finally can fit check the badge.
Intent Reveled
11/08/2017 at 07:07 • 0 commentsSo it turns out that this is not just a super tiny SLA printer, but it a HaD badge hack super tiny SLA printer.
It's coming together.
11/05/2017 at 18:06 • 0 commentsJacob: Printed base overnight. I thought it was going to be difficult to get off the print bed but it was actually quite easy. Assembled and fit check all the pieces. Need to reprint the coupler to avoid interference with display board.
Need to cut the lead screw and mount the build plate. Going to turn the machine over to Mike to complete these tasks.
Build Status
11/05/2017 at 06:24 • 0 commentsJacob: Printed pillow block and sensor mount today, base design is almost complete, hope to kick off a print tonight.
Michael: Built light cover and build chamber (and build chamber lid). Cut guide rods to length. Tested linear slide with test pieces along with a PONTECH STP300.
Hackaday.io component list leaves something to be desired.
11/04/2017 at 18:12 • 0 commentsHackaday.io component list leaves something to be desired so we put the BOM into Google Doc's:
Jacob Christ
