SLA 3D Printer HaD Super Con 2017 Badge Hacking
Portable super small low cost 3D SLA printer with a 30mm^3 print volume.
Make a portable super small low cost 3D SLA printer with a 30mm^3 print volume out of parts laying around the house.
Initial Question:
What can we do to top being rick rolled by SpriteTM
Initial Concept that stuck 3D SLA Printer.
Badge Github Repo:
https://github.com/JacobChrist/HaD-Super-Con-2017-Badge-Hacking-SLA-3D-Printer
Cover Unoptimized.svg
This is a first cut of a file to be used to cut the cover on Ponoko. This file should not be used to make the cover, it needs clean up, but its a place holder. To use this file the stroke width need to be set to 0.01mm and the fill needs to be removed.
svg+xml - 640.54 kB - 10/22/2017 at 19:56
Preview
1/4 20 threaded rod with a flat ground on one end. 1/4 20 coupling nut with taped holes for set screws
JPEG Image - 48.29 kB - 10/22/2017 at 14:53
Preview
View all 10 project logs
Anool Mahidharia wrote 11/11/2017 at 04:06 • point
Brilliant ! Keep the updates coming on how this shapes up
Mike Szczys wrote 11/10/2017 at 22:05 • point
Holy head start Batman. Great job!
Jacob Christ wrote 11/11/2017 at 02:48 • point
Thanks Mike, it means a lot coming from you.
