View of the BIOS
JPEG Image -
5.11 MB -
10/25/2017 at 15:22
Preview
Finished case rear view
JPEG Image -
4.78 MB -
10/25/2017 at 15:22
Preview
Finished case front left view
JPEG Image -
4.42 MB -
10/25/2017 at 15:22
Preview
Cluster running rear view
JPEG Image -
4.25 MB -
10/25/2017 at 15:22
Preview
Table of parts ready to build!
JPEG Image -
4.51 MB -
10/25/2017 at 15:22
Preview
SSD mounting hardware
JPEG Image -
4.25 MB -
10/25/2017 at 15:22
Preview
Finished case front right view
JPEG Image -
4.31 MB -
10/25/2017 at 15:22
Preview
Switches being installed inside view
JPEG Image -
4.02 MB -
10/25/2017 at 15:22
Preview
Test fitting PSU and cable lengths
JPEG Image -
4.02 MB -
10/25/2017 at 15:21
Preview
CAD case design using Onshape
JPEG Image -
4.19 MB -
10/25/2017 at 15:21
Preview
Cluster next to small computer
JPEG Image -
3.88 MB -
10/25/2017 at 15:21
Preview
Cluster running front view
JPEG Image -
3.95 MB -
10/25/2017 at 15:21
Preview
Router and switch bare boards
JPEG Image -
3.78 MB -
10/25/2017 at 15:21
Preview
Switches being install outside view
JPEG Image -
3.87 MB -
10/25/2017 at 15:21
Preview
Connecting and routing cables
JPEG Image -
3.93 MB -
10/25/2017 at 15:21
Preview
Ethernet cables connected
JPEG Image -
3.82 MB -
10/25/2017 at 15:21
Preview
Switch cables all soldered
JPEG Image -
3.86 MB -
10/25/2017 at 15:21
Preview
Case assembled top view
JPEG Image -
3.80 MB -
10/25/2017 at 15:21
Preview
First parts to arrive (switch, router, PSU)
JPEG Image -
3.85 MB -
10/25/2017 at 15:21
Preview
Case assembled rear view
JPEG Image -
3.76 MB -
10/25/2017 at 15:21
Preview
Double sided tape for CMOS battery
JPEG Image -
3.66 MB -
10/25/2017 at 15:21
Preview
Connected wire harnesses to PSU
JPEG Image -
3.77 MB -
10/25/2017 at 15:21
Preview
Bare router board and switch still in case
JPEG Image -
3.66 MB -
10/25/2017 at 15:21
Preview
Case first panels joined
JPEG Image -
3.61 MB -
10/25/2017 at 15:21
Preview
Switch mounted on panel
JPEG Image -
3.54 MB -
10/25/2017 at 15:21
Preview
First wire harness finished
JPEG Image -
3.50 MB -
10/25/2017 at 15:21
Preview
Testing board cooling alignment
JPEG Image -
3.37 MB -
10/25/2017 at 15:21
Preview
Finished soldering first wiring harness
JPEG Image -
3.25 MB -
10/25/2017 at 15:21
Preview
Starting soldering first wiring harness
JPEG Image -
3.35 MB -
10/25/2017 at 15:21
Preview
Board with CMOS battery and SSD mounted
JPEG Image -
3.25 MB -
10/25/2017 at 15:21
Preview
Cluster running top view
JPEG Image -
3.23 MB -
10/25/2017 at 15:21
Preview
Testing board cooling alignment (bad alignment)
JPEG Image -
3.28 MB -
10/25/2017 at 15:21
Preview
CMOS battery taped to board
JPEG Image -
2.94 MB -
10/25/2017 at 15:21
Preview
Router mounted to base
JPEG Image -
3.03 MB -
10/25/2017 at 15:21
Preview
Testing first t slot joint
JPEG Image -
2.74 MB -
10/25/2017 at 15:21
Preview
Peeling the protective acrylic film away
JPEG Image -
2.68 MB -
10/25/2017 at 15:21
Preview
Checking clearance between router and UDOO
JPEG Image -
2.93 MB -
10/25/2017 at 15:21
Preview
Soldering up switch wires
JPEG Image -
2.72 MB -
10/25/2017 at 15:21
Preview
Router mounting bottom panel screws
JPEG Image -
2.66 MB -
10/25/2017 at 15:21
Preview
Checking PSU t slot clearance (eek)
JPEG Image -
2.61 MB -
10/25/2017 at 15:21
Preview
