This project is meant to teach about utilizing neural networks in robotic platforms. There will be a 3 part video series on the Make YouTube channel on building the robot. It will start with prototyping and design, then move onto assembly and testing, and finally programming and running the neural network. You will be able to follow along and make your own robot in the end.
Details
3 Part Series is now up on my Channel. Check it out!
These tiny ones are 26:1 with plastic gearing, find them here: https://www.pololu.com/product/2357 They have some other gearing as well, and the specs available.
May I ask why the components with bit number D3 on the PCB board are not shown in the BOM list? What is the component with bit number D3
