screwpumpforhackaday.stl
This is a working Archimedes screw pump. The full print is 245.27 mm tall. This pump was developed to transport water from the swirl tank where large particles are filtered to the conditioning tank where the water levels are monitored. Parts for a filter which attaches to the end of this pump will be available soon.
Standard Tesselated Geometry -
509.85 kB -
08/07/2018 at 23:01
