11Glue the top and middle layer together
Glue the top and middle layer together. Clamps are your friend here. Also, anyone who has ever tried gluing and clamping flat pieces of wood, you know they have a tenancy to slide all over. A cool trick is to drop some salt into the clue... it only takes a few grains but the grid helps to keep the pieces from sliding as the clamps begin to apply pressure.
12Make the back layer.
The bottom layer is thinner than the others, roughly 1/4". The goal was to get it as thin as possible (since it will separate the wireless charger and receiver) while still being think enough that I don't have to worry about cracking it sometime down the road. All there really was to do for this layer was lay out a pattern and then drill and countersink the holes.
13Trim outer edges
With the top two layers glued and then the bottom layer screwed on the back, I ran the whole thing through the table saw to even out all of the outer edges.
