This is a crude ISA for the cpu.
The PHX8 has 16 "main" instructions encoded in the top 4 bits of the byte. Some of these also have an encoding in the lower 4 bits.
The main instructions are encoded as follows:
OPERATION CODE HIGH ENCODING: ------------------------------------------------------------------------------ HEX OPC OP DESCRIPTION ------------------------------------------------------------------------------ 00 nop - no operation DATA TRANSFER: 10 mov D, S move reg to reg 2- ld D, M load from memory to reg 3- st M, S store from memory to reg DATA OPERATIONS: 4- add D, S s add 5- adc D, S s add with carry 6- sub D, S s subtract 7- sbb D, S s subtract with borrow 8- and D, S s logical and 9- or D, S s logical or A- xor D, S s logical exclusive or B0 shr D, S shift right C- cmp S s compare unsigned SEQUENCING: D- jmp A jump E0 ret - return from jump F0 hlt - halt ------------------------------------------------------------------------------ D Destination S 1st Source s 2nd source A Address M Memory Address
Instructions with a X- instead of an X0 are further encoded as:
OPERATION CODE LOW ENCODING: ------------------------------------------------------------------------------ HEX OPC OP DESCRIPTION ------------------------------------------------------------------------------ LOAD: 20 ldi D, #00h load immediate into register 21 ldz D, L load indexed zeropage 22 ldz D, &00h load immediate zeropage 23 lda D, H:L load indexed absolute 24 lda D, &0000h load immediate absolute STORE: 30 stz L, S store indexed zeropage 31 stz &00h, S store immediate zeropage 32 sta H:L, S store indexed absolute 33 sta &0000h, S store immediate absolute ARITHMETIC & LOGIC: add, adc, sub, sbb, and, or, xor, cmp X0 ALU D, S s perform operation with registers X1 ALU D, S #00h perform operation with register and immediate value COMPARE: C0 cmp S s compare register to register C1 cmp S #00h compare register to immediate JUMP: D0 jmp H:L jump unconditional indexed absolute D1 jmp &0000h jump unconditional immediate absolute D2 jc H:L jump carry indexed absolute D3 jc &0000h jump carry immediate absolute D4 jv H:L jump overflow indexed absolute D5 jv &0000h jump overflow immediate absolute D6 jz H:L jump zero indexed absolute D7 jz &0000h jump zero immediate absolute D8 jn H:L jump negative indexed absolute D9 jn &0000h jump negative immediate absolute DA jg H:L jump greater indexed absolute DB jg &0000h jump greater immediate absolute DC jl H:L jump less indexed absolute DD jl &0000h jump less immediate absolute DE ji H:L jump input indexed absolute DF ji &0000h jump input immediate absolute ------------------------------------------------------------------------------ H,L High, Low: Register Index & Address 8 or 16 bits # Immediate value
All in all the Processor features 46 instructions.
1 No Operation
10 Data Transfer
17 Arithmetic & Logic
18 Sequencing
Now to the Processor Status Flags. These are used for the conditional jumps and are calculated/ overwritten if a Arithmetic, Logic or an Compare instruction is executed. With exeption of one flag: The Input Flag (I).
This flag turns 1 if the Processor recives an 8 bit value from the input port. This flag prevents overwriting an old value in the "Input Register" (IN) if I==1.
STATUS REGISTER (ST) ------------------------------------------------------------------------------ Bit Order: 7 6 5 4 3 2 1 0 C V Z N G L I - ------------------------------------------------------------------------------ C Carry =1 If a carry or borrow occurs (unsigned arithmetic) V Overflow =1 If arithmetic overflow occurs (signed arithmetic) Z Zero =1 If the Result is =0 OR If cmp S == s (Equal) N Negative =1 If the 7th bit is 1 (signed) G Greater =1 If cmp S > s L Less =1 If cmp S < s I Input =1 If Input is updated THE FOLLOWING OPERATIONS UPDATE THESE FLAGS: ------------------------------------------------------------------------------ OPC FLAGS ------------------------------------------------------------------------------ add C V Z N adc C V Z N sub C V Z N sbb C V Z N and Z N or Z N xor Z N shr C Z N cmp Z G L
Im still unsure how many Registers I should use (8 or 16) since the more registers I have the more wiring, breadboards and multiplexers I need. But these registers are for sure to implement:
GENERAL PURPOSE: A (at least 3 GPR) (1 for Arithmetic "A") (2 for indexing "X,Y") X Y SPECIAL: SR Status Register IN Input Register OT Output Register PH Program Counter High PL Program Counter Low
Every register is 8 bit wide and can be accessed by any instruction that deals with "adressable" registers.
Internal Registers like "Instruction Register" or "Instruction Sequencer" arent listed yet but i will get to them in another log.
