The PHX8 has 16 "main" instructions encoded in the top 4 bits of the byte. Some of these also have an encoding in the lower 4 bits.
The main instructions are encoded as follows:
OPERATION CODE HIGH ENCODING:
HEX OPC OP DESCRIPTION
00 nop - no operation
DATA TRANSFER:
10 mov D, S move reg to reg
2- ld D, M load from memory to reg
3- st M, S store from memory to reg
DATA OPERATIONS:
4- add D, S s add
5- adc D, S s add with carry
6- sub D, S s subtract
7- sbb D, S s subtract with borrow
8- and D, S s logical and
9- or D, S s logical or
A- xor D, S s logical exclusive or
B0 shr D, S shift right
C- cmp S s compare unsigned
SEQUENCING:
D- jmp A jump
E0 ret - return from jump
F0 hlt - halt
D Destination
S 1st Source
s 2nd source
A Address
M Memory Address
Instructions with a X- instead of an X0 are further encoded as:
OPERATION CODE LOW ENCODING:
LOAD:
20 ldi D, #00h load immediate into register
21 ldz D, L load indexed zeropage
22 ldz D, &00h load immediate zeropage
23 lda D, H:L load indexed absolute
24 lda D, &0000h load immediate absolute
STORE:
30 stz L, S store indexed zeropage
31 stz &00h, S store immediate zeropage
32 sta H:L, S store indexed absolute
33 sta &0000h, S store immediate absolute
ARITHMETIC & LOGIC:
add, adc, sub, sbb, and, or, xor, cmp
X0 ALU D, S s perform operation with registers
X1 ALU D, S #00h perform operation with register and immediate value
COMPARE:
C0 cmp S s compare register to register
C1 cmp S #00h compare register to immediate
JUMP:
D0 jmp H:L jump unconditional indexed absolute
D1 jmp &0000h jump unconditional immediate absolute
D2 jc H:L jump carry indexed absolute
D3 jc &0000h jump carry immediate absolute
D4 jv H:L jump overflow indexed absolute
D5 jv &0000h jump overflow immediate absolute
D6 jz H:L jump zero indexed absolute
D7 jz &0000h jump zero immediate absolute
D8 jn H:L jump negative indexed absolute
D9 jn &0000h jump negative immediate absolute
DA jg H:L jump greater indexed absolute
DB jg &0000h...
