PHX8 - Memory Unit
11/07/2017 at 20:13 • 0 commentsToday I have finished the Memory Unit.
It can store 64KB of memory (16 Address bits, 8 Data bits).Its made out of 2x 32KB SRAM chips and 1x Hex Inverter Chip (to control the selection of one of the two chips and the Write signal).
An Arduino with 2x 8bit Shift Registers is used to Read/ Write the SRAM.
PHX8 - Instruction Set Architecture
11/06/2017 at 18:37 • 0 commentsThis is a crude ISA for the cpu.
The PHX8 has 16 "main" instructions encoded in the top 4 bits of the byte. Some of these also have an encoding in the lower 4 bits.
The main instructions are encoded as follows:
OPERATION CODE HIGH ENCODING: ------------------------------------------------------------------------------ HEX OPC OP DESCRIPTION ------------------------------------------------------------------------------ 00 nop - no operation DATA TRANSFER: 10 mov D, S move reg to reg 2- ld D, M load from memory to reg 3- st M, S store from memory to reg DATA OPERATIONS: 4- add D, S s add 5- adc D, S s add with carry 6- sub D, S s subtract 7- sbb D, S s subtract with borrow 8- and D, S s logical and 9- or D, S s logical or A- xor D, S s logical exclusive or B0 shr D, S shift right C- cmp S s compare unsigned SEQUENCING: D- jmp A jump E0 ret - return from jump F0 hlt - halt ------------------------------------------------------------------------------ D Destination S 1st Source s 2nd source A Address M Memory Address
Instructions with a X- instead of an X0 are further encoded as:
OPERATION CODE LOW ENCODING: ------------------------------------------------------------------------------ HEX OPC OP DESCRIPTION ------------------------------------------------------------------------------ LOAD: 20 ldi D, #00h load immediate into register 21 ldz D, L load indexed zeropage 22 ldz D, &00h load immediate zeropage 23 lda D, H:L load indexed absolute 24 lda D, &0000h load immediate absolute STORE: 30 stz L, S store indexed zeropage 31 stz &00h, S store immediate zeropage 32 sta H:L, S store indexed absolute 33 sta &0000h, S store immediate absolute ARITHMETIC & LOGIC: add, adc, sub, sbb, and, or, xor, cmp X0 ALU D, S s perform operation with registers X1 ALU D, S #00h perform operation with register and immediate value COMPARE: C0 cmp S s compare register to register C1 cmp S #00h compare register to immediate JUMP: D0 jmp H:L jump unconditional indexed absolute D1 jmp &0000h jump unconditional immediate absolute D2 jc H:L jump carry indexed absolute D3 jc &0000h jump carry immediate absolute D4 jv H:L jump overflow indexed absolute D5 jv &0000h jump overflow immediate absolute D6 jz H:L jump zero indexed absolute D7 jz &0000h jump zero immediate absolute D8 jn H:L jump negative indexed absolute D9 jn &0000h jump negative immediate absolute DA jg H:L jump greater indexed absolute DB jg &0000h jump greater immediate absolute DC jl H:L jump less indexed absolute DD jl &0000h jump less immediate absolute DE ji H:L jump input indexed absolute DF ji &0000h jump input immediate absolute ------------------------------------------------------------------------------ H,L High, Low: Register Index & Address 8 or 16 bits # Immediate value
All in all the Processor features 46 instructions.
1 No Operation
10 Data Transfer
17 Arithmetic & Logic
18 Sequencing
Now to the Processor Status Flags. These are used for the conditional jumps and are calculated/ overwritten if a Arithmetic, Logic or an Compare instruction is executed. With exeption of one flag: The Input Flag (I).
This flag turns 1 if the Processor recives an 8 bit value from the input port. This flag prevents overwriting an old value in the "Input Register" (IN) if I==1.
STATUS REGISTER (ST) ------------------------------------------------------------------------------ Bit Order: 7 6 5 4 3 2 1 0 C V Z N G L I - ------------------------------------------------------------------------------ C Carry =1 If a carry or borrow occurs (unsigned arithmetic) V Overflow =1 If arithmetic overflow occurs (signed arithmetic) Z Zero =1 If the Result is =0 OR If cmp S == s (Equal) N Negative =1 If the 7th bit is 1 (signed) G Greater =1 If cmp S > s L Less =1 If cmp S < s I Input =1 If Input is updated THE FOLLOWING OPERATIONS UPDATE THESE FLAGS: ------------------------------------------------------------------------------ OPC FLAGS ------------------------------------------------------------------------------ add C V Z N adc C V Z N sub C V Z N sbb C V Z N and Z N or Z N xor Z N shr C Z N cmp Z G L
Im still unsure how many Registers I should use (8 or 16) since the more registers I have the more wiring, breadboards and multiplexers I need. But these registers are for sure to implement:
GENERAL PURPOSE: A (at least 3 GPR) (1 for Arithmetic "A") (2 for indexing "X,Y") X Y SPECIAL: SR Status Register IN Input Register OT Output Register PH Program Counter High PL Program Counter Low
Every register is 8 bit wide and can be accessed by any instruction that deals with "adressable" registers.
Internal Registers like "Instruction Register" or "Instruction Sequencer" arent listed yet but i will get to them in another log.
