I need high voltage capacitors for a few projects and I'm finding that at this point it is easier to create my own than buy (and wait for shipping.)
Components
3×
Dielectric
This can be anything non-conductive. I've experimented with rubber and polyethylene so far. Considerations should include price, availability, dielectric strength and the dielectric constant of the material. Dielectric should be larger than the conductors. You'll need at least a top, bottom, and middle piece.
2×
Conductor
I've experimented with strips of aluminum foil and aluminum (?) metal tape so far.
2×
Wire Leads
Always need some leads for your new component!
1×
Electrical tape
To keep the wound capacitor together.
Along with working out processes for fabricating capacitors, I created some tests with aluminum tape and polyethylene dielectric (of varying thicknesses.) Capacitance measured between 2 and 3 nanofarads.
Still working out lead placement, orientation, etc.
Along the way, I created a little jig to assist with creation. Right now I'm just using the measurement sections, but I've been working on a tool at the top to assist with wrapping capacitors on the top left. Not sure if it will be hand wound or motorized.
Still trying to find the best way to affix the leads. Solder connections on the aluminum tape are not great. May be solved by dipping in sealant (wax, epoxy, resin) and drawing a vacuum on it to get rid of air.
I'll wrap up with some process pics.
Connections soldered and then covered in metal tape.
As a proof of concept, I decided to try making a foil capacitor with a rubber dielectric. The plates were rolled together and secured with rubber bands to keep everything snug.
Capacitance was read by connecting leads to aluminum tabs extruding from opposite ends of the capacitor. A Fluke 17B+ was used for measurements.
Wikipedia lists the dielectric strength of neoprene rubber between 15.7 - 26.7 MV/m which gives us a minimum breakdown voltage of around 24,923 volts and a maximum of 42,386 volts.
