Elecrow Christmas PCB feast now open.
Share in Elecrow facebook group (Recommended)
Share on Elecrow Review Page (alternative if you don't use facebook)
If you have no idea what to do, I will introduce you the projects from our customers that may light up your inspiration. Let's see what our customers accomplished last year.
(#2 #3 #4 #5 #6 Christmas creative items are available at Elecrow PCB Christmas Special page )
#1 The Youngest- PCB Trees and Stars
This is a project of father's task made by the kids . They are the youngest participant in Elecrow Christmas PCB contest. This project may be their first time to make their own Christmas decorations with PCB. I guess this items would be their unforgettable memory of Christmas 2016. Although this design are neat, I'm sure they can do much better one in the future.
#2 The Most Liked- WS2812B LED Stars Bunch
This is the champion project. You can use Arduino to control these WS2812B leds. The stars can be made any visual effect and on the each star the visual effect can be different at the same time. You're limited only by the imagination and programming skill. The creator Tomek Dutka also designed a snowflake Christmas PCB ornament, you can click the words link to find more description, images and videos of his project.
#3 The Most Adorable- Big Pink Nose Elk PCB
This cartoon Elk PCB artwork makes people laugh, kinds of humor design. The circuit is pretty simple, but the sculpt make it standout. Actually, you can make your own funny PCB items even you're not specialized in PCB layout.
#4 The Most Exquisite- PCB Cube with Warm Image
The boards have to be manually depanelized and soldered in a shape of a lantern. On the top square pcb a WS2812B LED has to be mounted in order to illuminate the interior of lantern. Due to the fact that 0.6mm pcb's are quite transparent, images printed on copper layers, solder mask and overlay layers will be clearly visible.
#5 The Most Twinkling- Hexagon PCB with Golden Snowflake
The hexagon black boards are decorated with ENIG snowflake and double side...
Elecrow
Abduulah Omran
Hendra Kusumah
