Testing grasping and moving an objects
03/21/2018 at 00:54 • 0 commentsThe robot has a manipulator with 4 degrees of freedom. All rotary axes are controlled from the 2.4 GHz transmitter. In the following video we can see how the robot grabs and lifts a screwdriver and a wheel from the floor.
Custom application for 6WD security robot
02/06/2018 at 12:21 • 0 commentsCurrently I'm developing a dedicated application for 6WD security robot. This app providing the following functionality:
- preview and record the image in real time
- snapshots
- detecting moving objects
- marking detection zones
- automatic sending of alarm notifications
I'm using Python, OpenCV and TensorFlow when creating and testing this software.
Testing preview from WiFi and FPV cameras
02/05/2018 at 01:49 • 0 commentsThe view from the wifi camera is displayed on the smartphone and from the fpv camera on the laptop.
Cameras used in the project:
1. RunCam OWL Plus - https://goo.gl/4fSgZ5
2. XiaoMi YI Wifi camera -
The first tests on the snow
01/23/2018 at 15:05 • 0 commentsDue to winter conditions in my area, I decided to do field tests in a nearby forest. How did it go? See for yourself ;)
Grasping and moving an object based on a camera view
01/16/2018 at 08:48 • 2 commentsThe first tests of grasping and moving an object based on a camera view. The inspection robot is remotely controlled from a safe distance by the operator.
Tests in rough terrain
12/30/2017 at 22:58 • 0 commentsTests of a 6-wheel robot in rough terrain. Overcoming obstacles at different speeds.
The first tests of 6WD robot
12/28/2017 at 19:20 • 0 commentsThe above video shows the first tests of 6WD robot in my room. This robot is able to carry a load of several kilos very easily, on the video it transports 8 bottles of water equivalent to 12 kg. The robot can also easily overcome various obstacles encountered on its way. The speed of the robot is regulated in its full range via a 2.4 GHz transmitter.
The parts needed:
1. DC 12V 180RPM High Torque Gear Reducer Motor - https://goo.gl/UtnKRi
2. Tires HSP 1:10 Monster Truck - https://goo.gl/vtCiwX
3. Arduino mega 2560 - https://goo.gl/G5MxXs
4. VL53L0X Laser ToF Sensor - https://goo.gl/PpStN2
5. 5500mAh 3S 45C Lipo Battery -- https://goo.gl/N3tUf9
6. Stainless Steel Power Push Button Switch - https://goo.gl/ScvF9JControl:
1. FrSky TARANIS Q X7 2.4GHz 7CH Transmitter - https://goo.gl/3JhLwe
2. FlySky FS 2.4GHz 6 CH Receiver - https://goo.gl/afmiPq -
Automatic gripping of an object
12/15/2017 at 11:15 • 0 commentsAutomatic gripping of an object that has been detected by the VL53L0X laser sensor. Depending on the distance in which the object is from the gripper, it closes or opens so that it can easily grab the object.
Parts:
1. VL53L0X Laser ToF Sensor - https://goo.gl/PpStN2
2. CJMCU-219 Current Monitor Sensor Module - https://goo.gl/dmRR5c
3. Digital Servo - https://goo.gl/Mgt8Xh
4. Arduino mega 2560 - https://goo.gl/G5MxXs
5. Robot metal gripper - https://goo.gl/uLgSp3
6. Breadboard - https://goo.gl/eeKuiuSource code: link
RunCam Split - getting the camera preview
12/03/2017 at 23:47 • 0 commentsJust a quick instruction how to connect the RunCam Split camera and get preview from it on the mobile device like a tablet or smartphone.
Gimbal connection and control
12/03/2017 at 18:22 • 0 commentsIn this project log I'll show you how to connect and control a 2 axis gimbal from Ehang Ghost Quadcopter using Taranis Q X7 2.4GHz transmitter and FrSky V8FR-II receiver.
codersilver
