Please have a look at: http://youtu.be/9DDiwiv45sU
coffeeMAKER will be the one-stop beverage solution for the smart home.
Similar? no this is not correct. A caffee mashien is much different like a cocktail mashine. A car is also nor like a bicycle!
Don't understand why your comment seems so rude. You're true when you say it's different like a bicycle and a car, but i've not say that they are the same. the two projects try to solve the same problems and that's why I've said "similar in multiple points".
We have the same problems and difficulties (like pooring some solid and liquid to a container) and my goal is initially to share about those problems and solutions not about the differences between a cocktail and a coffee or a car and a bicycle but if you don't want to it's up to you.
Good luck and have fun with your coffeeMAKER you already made a good job.
No i don't want to be rude. Sorry.
But .. a caffee mashine is much complexer than just move the cup and oppen the ventil. Your work is good, but this is complexer.
No problems, this is why I want to share with you, we have tried to think about a lot of possibilities and design to improve our prototype but that was not so easy this is why I'm really interested by your project to see how you solve thoses problems :)
Du hast dich mit "Ja!" Milch verraten ;)
