A good run today saw me complete the Firmware, no doubt modifications will be coming but things have progressed enough to move on to the Hardware.
The code is listed below.
from the App it is possible to adjust the setpoints for the Temperature, Humidity and Moisture level pressing the save button stores the values in the EEPROM of the ESP8266 which is read on start up should the 8266 ever be rebooted.
Blynk is a platform with iOS and Android apps to control
Arduino, Raspberry Pi and the likes over the Internet.
You can easily build graphic interfaces for all your
projects by simply dragging and dropping widgets.
Downloads, docs, tutorials: http://www.blynk.cc
Blynk community: http://community.blynk.cc
Social networks: http://www.fb.com/blynkapp
http://twitter.com/blynk_app
Blynk library is licensed under MIT license
/* Comment this out to disable prints and save space */
#define BLYNK_PRINT Serial
#include <SPI.h>
#include <ESP8266WiFi.h>
#include <BlynkSimpleEsp8266.h>
#include <SimpleTimer.h>
#include <DHT.h>
#include <EEPROM.h>
// You should get Auth Token in the Blynk App.
// Go to the Project Settings (nut icon).
char auth[] = "xxxx";
char ssid[] = "xxxx";
char pass[] = "xxxx";
bool level = 0;
int fan;
int mist;
int pump;
int lowWater;
int moisture = 0;
int dryLevel = 100;
int maxTemp = 30;
int minHumidity = 50;
float humidity = 0;
float temperature = 0;
#define DHTPIN D2 // What digital pin we're connected to
#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
DHT dht(DHTPIN, DHTTYPE);
SimpleTimer timer;
void readInputs()
digitalWrite(D8,HIGH); // turns on Moisture sensor
humidity = dht.readHumidity(); // Reads Humidity
temperature = dht.readTemperature(); // Reads Temperature
lowWater = digitalRead(D1); // Read Low water level sensor
moisture = analogRead(A0)/4; //read moisture sensor scales value to have a max of 255 for easy storage in EEPROM
digitalWrite(D8,LOW); // turns off moisture sensor
if (isnan(humidity) || isnan(temperature)) {
Serial.println("Failed to read from DHT sensor!");
return;
void reportToBlynk()
//Sends data values to Blynk
// Sets sliders to values from Controller
Blynk.virtualWrite(V1, dryLevel);
Blynk.virtualWrite(V2, minHumidity);
Blynk.virtualWrite(V3, maxTemp);
// Display Values
Blynk.virtualWrite(V5, humidity);
Blynk.virtualWrite(V6, temperature);
Blynk.virtualWrite(V7, moisture);
Blynk.virtualWrite(V4, moisture);
// Satus LED's
Blynk.virtualWrite(V12, fan); // Controls LEDs in App to indicate
Blynk.virtualWrite(V11, mist); // status of Pumps and fans etc
Blynk.virtualWrite(V10, pump);
Blynk.virtualWrite(V9, lowWater*255); // Low Water warning indicator. Reading the input pin returns 1 but need to scale up to 255 to drive the BLYNK LED widget to full brightnes so * 255
BLYNK_WRITE(V1)
/* gets called when Slider attched to virtual pin 1 in the Blynk app changes
sets the value of the sider to drylevel. This is the setpoint level for the
activation of the flood pump.
dryLevel = param.asInt(); // assigning incoming value from pin V1 as an int to the dryLevel variable
Serial.print ("Moisture set ");
Serial.println (dryLevel);
EEPROM.write(1,dryLevel); //Stores the value of drylevel to EEPROM
BLYNK_WRITE(V2)
* sets the min Humidity level for the mister to turn on
minHumidity =param.asInt();
Serial.print ("Humidty ");
Serial.println (minHumidity);
EEPROM.write(2,minHumidity); //Stores the value of minHumidity to EEPROM
BLYNK_WRITE(V3)
* sets the tempertaure level for the fans to come on
maxTemp = param.asInt();
Serial.print ("Temp Set ");
Serial.println ( maxTemp);
EEPROM.write(3,maxTemp); //Stores the value of maxTemp to EEPROM
BLYNK_WRITE(V8)
* Loads settings into EEPROM on Button press
EEPROM.commit();
void controlOutputs()
/* Turns on watre pump to irrigate the grow bed
Turns on fans to reduce temperature
Turns on mister to increase humidity
// GROW BED Moisture
if (moisture < dryLevel) { // compares the mositure level of the bed with the set point value
digitalWrite(D5, HIGH); // If the bed is too dry then turn on the flodd pump and irrigate the bed
pump = 255; // Sets Pump status
else {
digitalWrite(D5, LOW); // If the bed is moist - no need to turn on the pump.
pump = 0;
// Ambient Temperature
if (temperature > maxTemp){
digitalWrite(D6, HIGH); // Checks to see if Tempertaure is too high
fan = 255;
} // If the Temp is too High turn on the exhaust fan
else {
digitalWrite(D6, LOW); // If its no to high turn the fan is off
fan = 0;
// Humidity Control
if (humidity < minHumidity){ // Checks to see if Humidty is too low
digitalWrite(D7, HIGH); // If its too low turns on mister
mist = 255;
else {
digitalWrite(D7, LOW); // If its high enough turn the mister off
mist = 0;
void setup()
EEPROM.begin(512); // Initialise EEPROM for storing values
// Set Output pins to outputs
pinMode(D5, OUTPUT); // Moisture sensor
pinMode(D6, OUTPUT); // Flood Pump
pinMode(D7, OUTPUT); // Fans
pinMode(D8, OUTPUT); // Mister
// Debug console
Serial.begin(9600);
// Set up Blynk
Blynk.begin(auth, ssid, pass);
// Set up Humidty and temp sensor
dht.begin();
//Read default parameters from EEProm
dryLevel = EEPROM.read(1);
minHumidity = EEPROM.read(2);
maxTemp = EEPROM.read(3);
Serial.println(dryLevel);
Serial.println(minHumidity);
Serial.println(maxTemp);
// Setup a function to be called every second
// this is to limit reporting to Blynk to only once a second
timer.setInterval(1000L, reportToBlynk);
void loop()
readInputs();
controlOutputs();
Blynk.run();
timer.run(); // Initiates SimpleTimer
Saabman
