Goals:
- Redo Challice
- Add Dice Pile
- Clear Dice (Possibly Glow Dice)
- Resin
- Add Lighting
- NeoPixel RGB Ring
- Possibly UV LEDs
- Add Dice Pile
- Paint
- Black and Gold color scheme
- Wire
- Hollow out bases and figure out wire path
- Misc
- Add features
Challice:
"If the crown fits, wear it" - anonymous
This is the crown jewel of the project and likely where most of the focus is going to be. This being the focal point of the piece I'm hoping to really make it stand out. The goal is to have a pile of clear dice cast in resin, as if a pile of treasure, that will be lit from below.
Wiring:
"To see things differently requires you to be wired a little differently" - Fred Wilson
Wiring will be the heart and brains of this project. I want to conceal any wires so that this retains the look of a sports trophy. The frame of the trophy being mostly hollow works great for this project but the confined spaces and how the bases mount together might be an issue.
Mikhail Thomas
Chris Low
Mike
Simply7
RossGK Tangibles
Always looking for input/feedback on how I could make this project better!
