Our device has:
- 3.5 x 3.5 mm RGB LEDs with controller (SK6812 mini) with extension pads (you can add more LEDs or LED stripe)
- MCU Atmel Attiny 85 with programming interface pinout
- analog sensor (photoresistor, thermoresistor)
- 3V battery connector (CR2032 or CR2016)
- power switch
Size - 30 x 30 mm.
We can use photoresistor or thermoresistor as analog sensor. Device can be programmed it with Arduino IDE, using Arduino Nano for uploading (Arduino ISP).
Maxim Krentovskiy
ikhsan ismail
looks awesome. Any chance of doing a video and seeing all the bits put together etc. thank you happy new year
