Hackaday.io Hackaday.io
Sign up Log in
ESP-12 SOCKET ADAPTER SOLDERLESS FLASHER
ESP-12 SOCKET SOLDERLESS FLASHER ADAPTER
eduardo-zolaEduardo Zola
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
7.3k views
6 comments
32 followers
  • Description
  • Details
  • Files 3
    • View all
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 6
  • The 2018 Hackaday Prize
View Gallery
7.3k
6
32
50
Team (1)
  • eduardo-zolaEduardo Zola
Join this project's team
  • YOUTUBE
hardware
completed project
2018hackadayprize firmware programmer adapter zola eduardo zola zolalab pcb ESP8266 upload SOCKET ESP12 Flashing esp-12F flasher solderless
Related lists
2018 THP: Digikey Parts
Hackaday Prize entries using Digikey parts
This project is submitted for
  • Hackaday.com Tip Line
  • Open Hardware Design Challenge
This project was created on 12/02/2017 and last updated 8 years ago.
Description
I believe that just like me, many of you have already had to flash a firmware to the ESP-12 before soldering it on a pcb. So I made a video showing how I solved this problem.
Details
Files
PCB GERBER ESP12 FLASHING ADAPTER.zip
x-zip-compressed - 42.14 kB - 04/18/2018 at 19:28
Download
Portable Network Graphics (PNG) - 36.47 kB - 04/18/2018 at 19:27
Preview
Portable Network Graphics (PNG) - 32.99 kB - 04/18/2018 at 19:27
Preview
Log In/Sign up to comment
Sign up with Github
OR
SAMUEL NKOTTO wrote 01/14/2018 at 10:13 • point
coool
evgeny.zislis wrote 12/21/2017 at 03:37 • point
I did something similar with pogo pins which looks a bit more rigid https://hackaday.io/project/20944-esp-12-esp8266-pogo-jig
Ronald Gordon wrote 12/16/2017 at 14:13 • point
This is my first view; so, pardon my ignorance of your progress. The pin-set options would seem to route "certified" library routines embedded in firmware, thus allowing visual/tactile block design (flow-charting) -- a far superior human interface for rapid APP development.  Concept shows promise for embedded breadboard demonstrations (aerospace, analog /hybrid system diagnostics, low-risk interim patching)  -- exploratory surgery without the invasion, and a valuable tool for competitive "design-off".  Secure interfacing would allow unclassified development and sharing without disclosure, thus expanding access to 3rd party developers and faster adaptation of off-the-shelf commercial APPs.
Since you have a physical air-gap, you also have inherent non-traceability/detection (spyware); and with some enhancements, guaranteed hardness -- an historically frustrating hurtle for advances in EMP-survivable operating environments. That's why the Minuteman still flies guided by 50's era technologies (drum and loop memories).
Out of the box, I see a toolset for rapid, self-documenting reverse engineering, troubleshooting, and conceptual "what-if". (Have suitcase, will travel.)
My first "tech" job in my teens was in a data processing center in England that included "programming" plug boards. https://en.wikipedia.org/wiki/Plugboard  I wheeled around racks of punch cards  for sorting, collating, and "computing" (adding, subtracting and printing) maintenance data for military aircraft.  Placards for our program boards hung on the wall arranged by report period (daily, weekly, monthly) with colored string pinned to the wall indicating the order-of-pull for each step in a specific report process. Our database was a quonset hut of IBM card boxes, mylar punch tape reels, and tractor-feed green-and-white paper reports, again stored chronologically by periodicity.  The advent of magnetic storage devices (tape, floppies, and hard drives) wiped out the punch technology due to obvious space-savings and apparent improved durability -- only to soon learn that magnetic storage media have disturbingly short shelf-lives and are vulnerable to EMP.  Of course, real computers erased data calculating machines all together.
In 70's I  flow charted a CRT display program (Apple III) to virtually wire a plug board for what we then called NC machining. Never did the coding (Fortran).  Seemed like a step back; but, here we are full circle! Lovely.
You guessed it; I'm older than dirt. Apologize for the nostalgic outburst. Looks like a fun project with promising applications. Wish you success.
jean.perardel wrote 12/12/2017 at 12:05 • point
Awesome!! It doesn't seem very stable, but I love the originality of the solution :)
Eduardo Zola wrote 12/12/2017 at 15:53 • point
Thank you !  Believe, it is very stable.
zoobab wrote 12/04/2017 at 13:01 • point
You could also hold the chip with a clothespin, like I did some days ago with another device:
https://twitter.com/zoobab/status/936563029377978368
A breadboard friendley Breakout for ESP8266-07 modules with some extra functions.
Project Owner Contributor
ESP8266-07 Breakout
jan-bJan B.
A simple USB Interface to generate the necessary signals to programm an ESP-01 module with AutoProgram!
ESP(32)-01 Programmer
thomas-buckThomas Buck
Simple PCB Widget to Upgrade/flash latest firmware SDK into ESP-01 ESP-12. Single PCB, with integrated ESP - 01/12 connectivity.
ESP8266-01/12 - Upgrader / Flasher
amar-potdarAmar Potdar
This PCB can do firmware download on any AeonLabs PCB designs or any other PCB running at 3.0V or 5.0V
AeonLabs MCU Burner USB to UART TTL
miguel-tomasMiguel Tomas
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "ESP-12 SOCKET ADAPTER SOLDERLESS FLASHER", please tell us the reason.
Send message
Remove Member
