USB CDC Robosapien V1
Robosapien's actions controlled through a virtual USB port. Speaker switchable between Robosapien & external audio jack
2017 :
✓Digistump controlling the Robosapien's actions through IR-wedge
✓Digistump accepting commands from the virtual serial port
✓Robosapien's voice switchable between internal Robospeech and external audio input through 3.5mm jack.
✓Implement the above on a PCB and mount it in the Robosapien
2021 :
After a few years of neglecting this project, I was in for an unpleasant surprise. The Robosapien no longer shows up as a virtual COM-port. The main issue seems to be the unreliability of the Digistump USB bitbang technique.
✈ Linux SBC controlling Robosapien's actions & audio
Implementation details
Power
The Robosapien was originally powered by four 1.5V size "D" cells, two in each foot.  The weight in the foot is needed for stability during walking.  If no weight is placed in the feet, the Robosapien will fall over during walking.  The weight of a "D"-cell varies from 135g-200g, depending on battery chemistry and amp-rating.
The robot will now be powered from 5V USB.  The connection can be made as follows:
  • Connector marked "L-SW-GND-C" on the main-PCB:
    • use "GND" as USB-GND
    • "C" connected the batteries on the left foot with the ones in the right foot, it can be disconnected now.
  • On/off switch panel on the back plate : solder 5V from Digistump to "IN" on switch PCB.
5V connection to IN-signal of switch-PCB.
By making the connections in this way, the power button on the back will still be functional. VCC = supply voltage for most of the circuitry = 3.3V. U1 on the main PCB generates VCC from VDD. VDD = supply voltage for motor driver and speaker = 5V.
IROUT electrical connection
The IROUT-signal on the main PCB is 3V3-logic.  The Digistump is 5V-logic.  Care must also be taken to avoid latchup when the Robosapien is powered off while the Digistump is on.
IROUT has been pulled up to VCC with a 1K-resistor.  A BAT46W-schottky diode is used to connect to the Digistump.  The anode of the BAT46WJ is connected to IROUT.  The cathode is connected to the Digistump GPIO (i.e. the P0-pin).
The IROUT-waveforms look ok.
Photograph of the main-PCB with IROUT connection during debug.
Once this worked, I designed the PCB that gets mounted into the Robosapien's leg.  The diode is incorporated into that PCB so it's no longer needed to solder one on the Robosapien's main board.
Python
To get the events from the calendar, either pyexchange is used for on-premises servers or exchangelib for Microsoft 365.
The TTS-engine has also been replaced by a python library, enabling migration to Windows platforms.
Schematic_Robosapien-USB-Audio-interface_2021-11-08.pdf
R1.0 of the Robosapien USB & Audio interface This is the PCB that is mounted into the Robosapien's leg.
Adobe Portable Document Format - 36.46 kB - 11/08/2021 at 20:55
Preview
Robosapien-manual.pdf
Original manual of the Robosapien V1
Adobe Portable Document Format - 2.75 MB - 12/04/2017 at 19:00
Preview
  • RS Wedge mechanics
    Christoph Tack11/09/2021 at 18:47 0 comments
    Location of the wedge
    The internals of the Robosapien leave little room to add PCB's inside the housing.  There's some room in the back around the speaker, but it's hard to connect the micro-USB connection from there.
    The upper leg parts leave enough room for the PCB and make it quite easy to allow connection for micro-USB and audio.
    My original idea was to put the PCB (design in EasyEDA).  In the upper right leg.  Unfortunately the JST-XH connector are too high.  It's a pity that I'd made a cutout in the upper right leg before realizing that.
    Either I could redesign the PCB, moving the connectors to the top edge, or I could mount the PCB 180° rotated in the upper left leg.  I went for the second option.  The fit is less ideal.  Because the USB-connector is mounted lower, a bigger cutout in the leg is needed.  The USB-connector also rubs internally against the lower left leg, sometimes causing unreliable connection.  Maybe I'll fix that in the next PCB revision.
    RS Wedge mounted in upper leg
    As can be seen in the picture below, it would have been more practical to have the USB-connector where the 2-pins JST XH-connector is located now.  Component higher than 2mm must be avoided along the lower half of the PCB.
    PCB mounted in upper part of left leg
    Mounting done
    Connected audio and micro-USB to left leg
    Detail of left leg
  • References
    Christoph Tack10/29/2021 at 17:01 0 comments
  • Text to Speech
    Christoph Tack07/31/2020 at 13:32 0 comments
    Installation
    in Ubuntu
    sudo apt install libttspico-utils sox
    Convert text to speech
    pico2wave -w lookdave.wav "Look Dave, I can see you're really upset about this."
    Speech playback
    Using aplay
    aplay lookdave.wav
    Playing WAVE 'lookdave.wav' : Signed 16 bit Little Endian, Rate 16000 Hz, Mono
    Using play
    play -qV0 lookdave.wav treble 24 gain -l
    Adding speech effects
    The following command will convert the female voice to a robot voice.
    play lookdave.wav stretch 1.2 133.33 lin 0.2 0.4 echo 0.4 0.8 15 0.8 synth sine fmod 30 echo 0.8 0.8 29 0.8
    play WARN alsa: can't encode 0-bit Unknown or not applicable
    lookdave.wav:
     File Size: 119k      Bit Rate: 256k
      Encoding: Signed PCM
      Channels: 1 @ 16-bit
    Samplerate: 16000Hz
    Replaygain: off
      Duration: 00:00:03.72
    play WARN echo: echo: warning >>> gain-out can cause saturation of output <<<
    In:100%  00:00:03.72 [00:00:00.00] Out:72.0k [      |      ]        Clip:0
    Done.
  • RS Wedge firmware
    Christoph Tack04/10/2018 at 19:51 0 comments
    The firmware for the RS Wedge can be found on GitHub.
    Communication PC → RS Wedge : CLI
    To enable easy interfacing for humans as well as machines, a command line interface has been used.  The Arduino-CommandLine library has been used.
    Below you can find a capture of a command line session with the RoboSapien:
    Welcome to minicom 2.7
    OPTIONS: I18n
    Compiled on Feb  7 2016, 13:37:27.
    Port /dev/ttyACM0, 18:02:16
    Press CTRL-A Z for help on special keys
    > action 196
    > action 197
    > action 198
    > audio 0
    > action 198
    > action 197
    > action 197
    > action 196
    > action 195
    > audio 1
    Commands
    Two commands are implemented "action" and "audio".
    The "action" command executes one of the Robosapien standard actions.  On a standard Robosapien, you would have used the remote to start these actions.  A list of actions can be found in the source code of the RS wedge.
    The "audio" command switches the Robosapien's audio source : "0" selects the audio jack as source, which allows the connected laptop to route speech or music to the Robosapien.  "1" selects the Robosapien controller as source.
    Communication RS Wedge → Robosapien : IR protocol
    The easiest way to probe the original protocol is at the back of the main board, at the connector named "HEAD".  Remove this PCB, solder your probes to "GND" (black wire of "HEAD"-connector) and "IROUT" (white wire of "HEAD"-connector).
    The IR-protocol is quite simple.  The default state of the IR-OUT signal is high.  The message starts with a low pulse that lasts 6.26ms and is followed by databits 7 downto 0.
    • 0-bit =  0.843ms H + 0.843ms L
    • 1-bit = 3.512ms H + 0.843ms L
    Using this information, you should be able to figure out that the screen capture shows the 0xCE command.
    According to Aibohack, the protocol uses 1200baud.  I noticed quite a lot of jitter between bits.  Pulses of 909ms wide are not uncommon.
    Keeping the Robosapien awake
    • 5 minutes after startup, the Robosapien goes to sleep.  In sleep mode, no commands can be executed.  The "WAKE UP" must be sent to wake the unit up.  The Robosapien's wake-up routine is the same as when you power it up.  It's quite noisy.  You don't want to do this more than once a day.
    • Robosapien's manual : "After approx. 2 hours of uninterrupted sleep, he'll power himself off to save energy".
    Question: "How to keep the Robosapiens on indefinitely while keeping it still & quiet?"
    Answer: Sending 0xEF once a minute keeps the Robosapiens on.
  • RS wedge hardware
    Christoph Tack04/10/2018 at 18:56 0 comments
    Block diagram
    The original Digistump Wedge has been replaced by an Adafruit Trinket M0 because the USB-connection with the Digistump didn't work reliably.
    Wedge mounted between computer and Robosapien
    The RS Wedge has two functions:
    1. Converting commands from the PC to the IR-protocol that the Robosapien understands.
    2. Control an analog switch to select the Robosapien's speaker output between the PC-audio or the Robosapien internal audio.
    Electrical details
    Microcontroller
    To reduce the development time, a development has been chosen.  The Digistump clone has been selected in the end.  It has mounting holes, is small and contains a USB-connector.
    Audio output
    To be able to use the internal sound of the Robosapien as well as audio from the PC on the Robosapien's speaker, an analog switch is needed.
    The 74HC4053 will be used.  It's cheap and easily available.  Its three internal channels are connected in parallel.  In this application it doesn't matter much, but it decreases the series resistance of the multiplexer.
    The audio from the laptop is too weak to connect directly to the Robosapien's speaker, so we'll use an audio amplifier.  The PAM8403 is available on a PCB with the necessary peripheral circuitry.  These modules only cost a few cents.  The audio amplifier is connected at the output of the multiplexer.
    The audio output of the Robosapien can be taken from C13A.  This output is connected to a 10/2K2 voltage divider, which is connected to the analog multiplexer.  Decreasing the Robosapien to 1/6th of the original level is needed to avoid oversteering the amplifier.
    Finally the Digistump controls the state of the analog multiplexer, choosing between PC audio and Robosapien audio for the Robosapien speaker.
    Wiring to Robosapien main board
    3 wires soldered to Robosapien main board
    3 wires soldered to Robosapien main board.  GND (yellow), IR-OUT (brown), VCC(red) is the internal 3V3 supply of the Robosapien.  It's used as a reference voltage for IROUT-logic signals.
  • Audio connection on PC side
    Christoph Tack02/23/2018 at 19:59 0 comments
    In the final application, a BeagleBone Black (BBB) will be used to control the Robosapien.  Having one in my drawer is the only reason for using a BBB.  It unfortunately doesn't have an analog audio interface.
    Adding an external USB-Audio interface is a cheap (<€1) and easy solution.  It's supported by default in Ubuntu Linux.  The audio chipset is from Generalplus.  There's no more specific data.  I think it's either the GPD8102B or GPD8106B under the blob.
    AliExpress USB Audio interface
    Unluckily, in an attempt to cut down costs, the manufacturer has also cut down on specifications.  The audio output lacks low frequencies, which makes it very annoying to listen to.  Opening up the unit reveals that the audio is capacitively coupled.  This coupling capacitor forms a high pass filter with the input impedance of the headphones.  This device is cheap.  The capacitor is too small.  The cutoff frequency is too high, cutting off lower frequencies from the headphones.  Luckily, there's an easy fix:
    1. Open up the USB-audio interface.  Easiest way: drop it from 1m on a concrete floor.  For whatever reason (probably cost again) the housing is not glued.
    2. On the bottom you'l find C8 & C9.  These two 0805 caps are 10µF.
    3. Replace these caps with 22µF or higher value.  Higher cap values in small values are relatively expensive.  It's clear why they tried to save cost here.
    4. Normally, you should be able to assemble it without problems.
    • MIC-IN :
      • TIP + RING = MIC-IN
      •  SLEEVE = GND
    • AUDIO-OUT :
      • TIP = left
      • RING = right
      • SLEEVE = GND
  • Legacy : Getting started with Digistump clone
    Christoph Tack02/16/2018 at 21:11 0 comments
    2021 Update : Dump the Digistump
    As Adafruit also remarked for its Protrinket 3V: the bitbang USB technique doesn't work as well as in 2014.  The Digistump still works when directly connected to my Thinkpad laptop (on Linux), but not when connected through a USB-hub.  On Windows, it doesn't work at all.
    So another platform will be needed with native USB.  I think of the Adafruit Trinket M0 or the Seeeduino XIAO.  The annoying thing is that the Robosapien wedge is mounted using the mounting holes of the Digistump.  We'll have to fix that.
    For your reference, the historical Digistump info can be found here below.
    Where to buy?
    • Digispark website
    • AliExpress
      • This clone has two mounting holes, which is an advantage over the original Digistump.
      • The LED is on P1, not on P0.
    Installation
    Follow the instructions on:
    Programming
    The Digistump clone is shipped with a functioning bootloader.
    To program the application: first click verify, after that power on the Digistump.
    Further reading
    Marcus Jenkins wrote an interesting tips & tricks to get you started with the Digistump clone.
    Use a USB hub with a power switch for every outgoing USB port.  As such you can easiliy reprogram the Digistump without having you to replug it to the USB-port every time.
    The schematic can be found here.
View all 7 project logs
