Hackaday.io Hackaday.io
Sign up Log in
Robot Pendant
Robot pendant to control my Thor or Smartrobo robotarms
dannyvandenheuveldannyvandenheuvel
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
4.5k views
7 comments
24 followers
  • Description
  • Details
  • Files 3
    • View all
  • Components 10
    • View all
  • Logs 5
    • View all
  • Instructions 0
  • Discussion 7
  • The 2018 Hackaday Prize
View Gallery
4.5k
7
24
21
Team (1)
  • dannyvandenheuveldannyvandenheuvel
Join this project's team
ongoing project
2018hackadayprize
Related lists
2018 THP: Digikey Parts
Hackaday Prize entries using Digikey parts
This project is submitted for
  • Open Hardware Design Challenge
  • Robotics Module Challenge
This project was created on 12/07/2017 and last updated 8 years ago.
Description
Robot teach pendant to control my Thor or Smartrobo robotarms, Raspberry PI with 7" touchscreen programming with Python and Tkinter, wireless wifi , battery powered with autonomy of 4 hours, reloadable with usb or power supply. You can use this controller to make your own robot guiding :-)
Files
BACK_PARTS.zip
Back split in two parts
x-zip-compressed - 457.55 kB - 11/01/2018 at 13:13
Download
PENDANTV1.1_STL.rar
Pendant V1.1 STL files
RAR Archive - 3.28 MB - 12/25/2017 at 01:11
Download
PENDANTV1.1_STEP.rar
Pendant V1.1 STEP files
RAR Archive - 2.98 MB - 12/25/2017 at 01:10
Download
Components
  • 1 × Raspberry pi 3
  • 1 × Raspberry touchpanel 7"
  • 1 × Power bank 6000mAh Varta 57960
  • 1 × USB connector
  • 1 × Mini usb connector
View all 10 components
Project Logs
Collapse
  • PROGRAMMING THE TEACH PENDANT WITH QT
    dannyvandenheuvel • 01/03/2018 at 20:39 • 2 comments
  • PENDANT HAS BEEN BORN
    dannyvandenheuvel • 12/25/2017 at 01:04 • 0 comments
    This is a pendant to control my Thor & Smartrobo robotarm.
    I'm started to write the code for it :-)
  • Assembling the first parts
    dannyvandenheuvel • 12/22/2017 at 20:52 • 2 comments
     The first two biggest parts added togetter, looking good!
  • Building the parts
    dannyvandenheuvel • 12/22/2017 at 14:28 • 0 comments
    The front panel of the pendant, looking good, printed in rPLA from Filamentive
    Printing the back
    This is a long printing process, running about 24 hours but looking good at the moment, cross my fingers.
  • Robot Pendant
    dannyvandenheuvel • 12/08/2017 at 17:40 • 1 comment
    Robot Pendant for my THOR and or SMARTROBO arms :-)
View all 5 project logs
Log In/Sign up to comment
Sign up with Github
OR
i900032 wrote 06/16/2025 at 09:57 • point
CAN U FINNSH THE SOFTWEAR SO I CAN JUST ADD TO THE SD FOR THE PI  I PAY U PLS AMD THE MANUAL FOR THE SMRAT ROBOT V 2 PLS  I900032@GMAIL.COM   +61450185950
i900032 wrote 07/19/2024 at 11:22 • point
hello can u send the software for the robot and the pendant pls i pay u for ur time pls iam dome the pendant it turns but no software how to wire e stop thanks Pawel
i900032 wrote 08/11/2022 at 15:26 • point
how to wire estop pls thanks
i900032 wrote 08/11/2022 at 14:43 • point
have got the code yet thanks
goodcat432157 wrote 11/01/2018 at 12:29 • point
Hello,
pleas split the back file int two peaces. Is too big for my printer.
LG Marcel
dannyvandenheuvel wrote 11/01/2018 at 13:12 • point
Hi Marcel,
I updated this page with the back split in two.
best regard,
Danny
goodcat432157 wrote 11/01/2018 at 13:29 • point
thank you :)
The manipulator
Project Owner Contributor
SCARA robot
karolgalkaKarolGalka
We are building a robot maker community around vigibot.com allowing you to control anything you want over the internet with low latency!
Vigibot, the ultimate web remote controller!
mikemike
Supplyframe DesignLab: 2022 Hackada…
The robot can draw a picture on a wall I name it is "Fumik"
Wall Drawing Robot, Open Source
engineer2youengineer2you
The 2015 Hackaday Prize
An Open-Source Initiative to Build Multi-Robot Cyborgs
CyborgDistro
prateektprateekt
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Robot Pendant", please tell us the reason.
Send message
Remove Member
