Hackaday.io Hackaday.io
Sign up Log in
Robot Pendant
Robot pendant to control my Thor or Smartrobo robotarms
dannyvandenheuveldannyvandenheuvel
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
4.5k views
7 comments
24 followers
  • Description
  • Details
  • Files 3
    • View all
  • Components 10
    • View all
  • Logs 5
    • View all
  • Instructions 0
  • Discussion 7
  • The 2018 Hackaday Prize
View Gallery
4.5k
7
24
21
Team (1)
  • dannyvandenheuveldannyvandenheuvel
Join this project's team
ongoing project
2018hackadayprize
Related lists
2018 THP: Digikey Parts
Hackaday Prize entries using Digikey parts
This project is submitted for
  • Open Hardware Design Challenge
  • Robotics Module Challenge
This project was created on 12/07/2017 and last updated 8 years ago.
Description
Robot teach pendant to control my Thor or Smartrobo robotarms, Raspberry PI with 7" touchscreen programming with Python and Tkinter, wireless wifi , battery powered with autonomy of 4 hours, reloadable with usb or power supply. You can use this controller to make your own robot guiding :-)
Files
BACK_PARTS.zip
Back split in two parts
x-zip-compressed - 457.55 kB - 11/01/2018 at 13:13
Download
PENDANTV1.1_STL.rar
Pendant V1.1 STL files
RAR Archive - 3.28 MB - 12/25/2017 at 01:11
Download
PENDANTV1.1_STEP.rar
Pendant V1.1 STEP files
RAR Archive - 2.98 MB - 12/25/2017 at 01:10
Download
Components
  • 1 × Raspberry pi 3
  • 1 × Raspberry touchpanel 7"
  • 1 × Power bank 6000mAh Varta 57960
  • 1 × USB connector
  • 1 × Mini usb connector
View all 10 components
Project Logs
Collapse
  • PROGRAMMING THE TEACH PENDANT WITH QT
    dannyvandenheuvel • 01/03/2018 at 20:39 • 2 comments
  • PENDANT HAS BEEN BORN
    dannyvandenheuvel • 12/25/2017 at 01:04 • 0 comments
    This is a pendant to control my Thor & Smartrobo robotarm.
    I'm started to write the code for it :-)
  • Assembling the first parts
    dannyvandenheuvel • 12/22/2017 at 20:52 • 2 comments
     The first two biggest parts added togetter, looking good!
  • Building the parts
    dannyvandenheuvel • 12/22/2017 at 14:28 • 0 comments
    The front panel of the pendant, looking good, printed in rPLA from Filamentive
    Printing the back
    This is a long printing process, running about 24 hours but looking good at the moment, cross my fingers.
  • Robot Pendant
    dannyvandenheuvel • 12/08/2017 at 17:40 • 1 comment
    Robot Pendant for my THOR and or SMARTROBO arms :-)
View all 5 project logs
Log In/Sign up to comment
Sign up with Github
OR
i900032 wrote 06/16/2025 at 09:57 • point
CAN U FINNSH THE SOFTWEAR SO I CAN JUST ADD TO THE SD FOR THE PI  I PAY U PLS AMD THE MANUAL FOR THE SMRAT ROBOT V 2 PLS  I900032@GMAIL.COM   +61450185950
i900032 wrote 07/19/2024 at 11:22 • point
hello can u send the software for the robot and the pendant pls i pay u for ur time pls iam dome the pendant it turns but no software how to wire e stop thanks Pawel
i900032 wrote 08/11/2022 at 15:26 • point
how to wire estop pls thanks
i900032 wrote 08/11/2022 at 14:43 • point
have got the code yet thanks
goodcat432157 wrote 11/01/2018 at 12:29 • point
Hello,
pleas split the back file int two peaces. Is too big for my printer.
LG Marcel
dannyvandenheuvel wrote 11/01/2018 at 13:12 • point
Hi Marcel,
I updated this page with the back split in two.
best regard,
Danny
goodcat432157 wrote 11/01/2018 at 13:29 • point
thank you :)
The 2017 Hackaday Prize
Upgraded robot for telepresence and VR experiments
Project Owner Contributor
Bástya V1.5
btomBTom
The manipulator
SCARA robot
karolgalkaKarolGalka
This project controls an robot arm remotely by moving a similar robot arm. The sensing arm looks like a joystick to the computer.
Robot Arm Controller
tim-wilkinsonTim Wilkinson
We are building a robot maker community around vigibot.com allowing you to control anything you want over the internet with low latency!
Vigibot, the ultimate web remote controller!
mikemike
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Robot Pendant", please tell us the reason.
Send message
Remove Member
