Heroineclock II
Giant clock from a PIC18F6585, 135 cheap LEDs, foam core posterboard, hot glue, lots of hot glue
Originally a clock that grew into a wall of measurements. Visible without contact lenses from all areas of the apartment.
It was a long & hard process between 1 month of commutes, but Heroineclock I was finally shut down after 13 years of blinking & replaced by a much better Heroineclock II, factoring in much more experience.
All the Chinese options which appeared in the last 13 years were studied & found to be too expensive. The largest Chinese digits were 12" tall & $50. EL wire would cost a fortune. Projectors were too dim & small. Superbright red LEDs had dropped from 22c to 15c & become much brighter.
With the new experience, power consumption dropped from over 20W for Heroineclock I to 7W, yet light output increased greatly. The audio synthesizer was much more sophisticated, with 3 square wave oscillators & decay timing. The clockspeed was increased from 20Mhz to 40Mhz to allow the improved audio. The new speaker driver was a real PWM driven class D with the 0 crossing at 50% duty cycle. The speaker brought the total current with all the LEDs & sound to 0.6A.
The flaky buttons & switches which plagued Heroineclock I were replaced with an IR remote. It was a 1st experience decoding an IR remote & it revealed IR receivers don't output RS232 but PWM. The IR decoding ended up really schmick for it to handle the rapid button presses involved in setting a clock.  Modern LCD TV's have horribly slow IR parsing, in comparison.
The shift registers which drove Heroineclock I's LEDs were replaced by direct wiring to 1 GPIO per segment. A PIC18F6585 replaced the old PIC16F877. It had a massive number of pins, but only enough actively driven GPIOs for 27 segments. Instead of PNP transistors, the LEDs were driven by NPN's, allowing higher voltage. Instead of wiring the LEDs in parallel with massive amounts of current supplied to 2.5V bus lines, they were now 5 in series with 10V bus lines. The total current with all LEDs on was now 0.5A instead of 10A.
There's a small program to convert MIDI files into data tables for the clock to play back.  For the simple clock chimes, it was easier just to enter the data tables manually.  Having infinite note length & relying on the software decay made a more pleasing sound than having a defined note length.
For all the improved electronics, the whole thing could have been done much more easily with a raspberry pi playing mp3 audio. But the PIC would still have been necessary for multiplexing the LEDs & it was cheaper to leave out the additional raspberry pi. It was still a bit satisfying to use in a practical, modern application, a retro 8 bit platform with the kind of massive PLCC package that adorned high end electronics, 30 years ago.
Source code for Heroineclock II & thermometers:
https://github.com/heroineworshiper/heroineclock
thermo.pcb
Obsolete
x-pcb-layout - 96.07 kB - 08/15/2018 at 07:03
Download
clock.pcb
Obsolete
x-pcb-layout - 81.99 kB - 08/15/2018 at 07:03
Download
thermo.c
Obsolete
x-csrc - 16.37 kB - 08/15/2018 at 07:02
Download
temp_tester.c
Obsolete
x-csrc - 2.04 kB - 08/15/2018 at 07:01
Download
clock.062217.tar.xz
Obsolete
x-xz - 239.59 kB - 12/07/2017 at 22:17
Download
  • Diffuser upgrade
    lion mclionhead10/10/2022 at 01:31 0 comments
    The humidifier chewed up the wax paper, so it was time
    To upgrade most of the weather wall to LCD panel diffuser.  Sadly, it's not as diffuse as wax paper.
    Heroineclock had to be cleaned of many critters.
    Outside thermometer got HP panel diffuser.  Heroineclock II got Dell diffuser which was decidedly less diffuse.  Inside thermometer remaned wax paper, since it's held up better.
    The heroineclock icons remaned wax paper since they're covered.  Wax paper definitely degrades if it's exposed.  Heroineclock I lasted 15 years with enclosed wax paper.
    Future directions are going to have to be white PLA for the segments & diffusers.  The oil based paint of the past is no longer sold.  The diffusers aren't doing the business.  The segments might have to be 1" deep.
  • Hydrometer
    lion mclionhead06/10/2022 at 17:53 0 comments
    The weather wall got the world's most expensive hydrometer, an essential instrument for printing TPU & using a swamp cooler.  It was made from 2 day job boards.  Helas, the readout is too small for lions to be very happy with it.  At least it proved lions would not be happy with any commercial sized panel.
    Making 7 segment displays out of hundreds of bare LED's & transistors became somewhat of a drag over time.  There are LED strings, for a lot of money.
    It was surprising how much humidity varies from 25-50% in the apartment.  Taking showers while printing TPU is definitely out.  The lion kingdom still has barometer chips from 10 years ago, but Calif* rarely experiences any pressure changes.
  • Wunderground display
    lion mclionhead07/24/2021 at 06:52 0 comments
    Since retiring the solar powered weather station & displaying just downloaded temperature from wunderground, the display finally got tested by an outage.   Instead of showing a frozen out of date temperature & ceasing logging, it switched to the dashes as programmed & continued logging indoor temperature.
    After having nightmares about updating the wunderground URL every 2 months for the next 50 years, it turned out it was Xfinity going down for its annual 48 hour manetenance window.  Lions would prefer if Xfinity worked all 52 weeks instead of 51 weeks per year, but at least the lion software worked.
  • Solar panel death
    lion mclionhead04/03/2021 at 02:46 0 comments
    Only 7 months later, the solar panels lay on the floor after their packing tape farsteners decomposed & their hot glue wire harnesses melted.
    After scraping off the packing tape residue, the panels had bald spots.  They weren't glass but epoxy.  Scraping off the packing tape scraped off the gelcoat, so they were now less efficient.
    So the way the internet farstens solar panels is by putting their wires through holes & hot snotting the holes.  Higher end panels are clamped between 2 metal angle rods.  Doubt anything besides metal would last.
    Tried captain tape to make a short term solution at the expense of efficiency.  It didn't stick at all to the coroplastic.  It's amazing that the coroplastic & zip ties fended off the Calif* heat, but they haven't experienced the true fury of summer.
    This captain tape bodge with the scratched epoxy actually didn't affect the battery voltage.  It must be saturating the NiMH's.
    Another idea emerged whereby the panels would be under a sheet of acrylic.   The acrylic could have some borders made of PETG to retain the panels.  Then, captain tape would farsten the panels to the acrylic from the back.  Acrylic too would degrade, but might buy more than 7 months until the lion kingdom decided to risk cutting glass again.
  • TODO
    lion mclionhead11/02/2020 at 07:10 0 comments
    All the lion kingdom's LED displays were made before 3D printing arrived, even the outdoor thermometer.  3D printed white PLA actually could make a good diffuser.  The lighting isn't as even as some clocks, but much better than heroineclock II.  This guy threw a lot more money at store bought components instead of making everything from scratch.  There are individually addressible LED strips which can show different colors, a much more powerful computer which gets time from wifi, a much heavier enclosure which requires a lot more hardware to mount on a wall.  His other projects are manely toys, but there are a few good ideas.  Lions actually want the time to drift fast instead of precisely track wifi.  It could benefit from 3D printed diffusers, but not replacement of the LEDs.
  • New remote arrangement
    lion mclionhead09/19/2020 at 23:34 0 comments
    With the addition of seconds & the remote also supporting the robotic air vent, it was time for some adjustments.
  • Thermometer 3
    lion mclionhead08/14/2020 at 05:53 0 comments
    4 reconstituted autopilot boards from 10 years ago were reprogrammed & reworked for their new life as a sensor network.
    1 transmitter board transmits the temperature from outside.
    1 transmitter board transmits the temperature from inside.
    1 reciever board sends the temperatures to the router.
    1 receiver board sends the outside temperature to a new LED panel.
    The outdoor thermometer runs at 32.768khz.  The PIC18F14K50 was found to use 150uA in idle & up to 30mA when transmitting. It needs to transmit for a long time to overcome interference. The easiest error correction is to transmit more data.  The PIC uses its maximum baud rate of 8192 baud.  The internet said the sleep current is lower when using the watchdog timer instead of idle mode, but this was found to not be true.   The watchdog timer can go to 120 seconds, but it would have to take all its ADC readings at the moment of transmitting instead of averaging them over 120 seconds.
    The thermometers transmit a 16 byte key to identify themselves, followed by the temperature repeated 4 times.  The key & temperature are also repeated 4 times.
    The existing thermometer board got a retrofit to transmit temperature to the router.  After 16 years of just showing the temperature, giant thermometers could finally record the temperature.
    After much debate, the outdoor thermometer got a new voltage divider to measure battery voltage.   It doesn't need to measure battery voltage over its many years of temperature measurements.  It only needs the battery voltage to test the solar panels in its 1st day.  The problem is the alternative is to go outside with a voltmeter several times.
    Its idle current increased to 200uA & lions rediscovered the ground for the voltage divider can't be a GPIO or it'll sink the high voltage from the battery.  When the power usage is this low, the high voltage from the battery raises Vdd.
    As bad as the compromises seem, the power usage is actually tiny compared to a modern standards based solution.  The modern solutions use an ESP32 & wifi.  They have to stay on for a long time to negotiate a wifi connection, which tends to erase any gain from their nano amp sleep current.
    It was frustrating to discover despite being only a temperature sensor in a very suboptimal location, the enclosure still needed to be a proper weather station enclosure to get good results. Much cardboard prototyping yielded something like a bird house with a way to access the innards. Now the lion kingdom knows why it needed to keep around a speaker stand for 20 years. The mane problem is keeping the wind from giving the neighbors a free $90 thermometer. It's cost as much just to get temperature as a full chinese weather station.
    Thermometer with a smile, you might say.
    Junk NiMH battery from an ECX Ruckus rated for 7.2V.
    Waterproofing the battery.
    Trying to protect the electronicals from condensation.
    Failed attempt to isolate the thermistor from conducted heat.
    The enclosure size was dictated by the solar panels.
    The electronicals were buttoned up & it was put outside.  The thermister was 5 deg higher than wunderground at night & 15 deg high by day .  The fluke was 20 deg higher than wunderground at night & bang on by day, despite being in the exact same place inside the enclosure.  Location of the thermistor inside the enclosure affected temperature.  The area without circulation was much hotter than the area with circulation.  When indoors, the thermistor was bang on.
    The thermistor:
    https://www.digikey.com/product-detail/en/littelfuse-inc/DC103G9G/615-1054-ND/1783432
    A full day of measurements revealed it suffered from heat conduction. A new assembly made of magnet wire & balsa would conduct less heat from the coroplastic. This was still...
  • Exterior temperature plan
    lion mclionhead08/10/2020 at 04:42 0 comments
    With no need to spend all day commuting, there has been a growing desire to measure outdoor temperature without the grid & recording the indoor temperature.  There are a lot of temperature sensors on the internet, using ESP32 & ESP8266 boards, exotic capacitors, lithium phosphate batteries, space grade solar panels, sucking megawatts of power to promote the latest wifi standards.  It's all a bit overkill, but representative of a time that emphasizes very suboptimal, off the shelf parts using every multibillion dollar consortium's bloated standard.
    The lion kingdom still has a lot of very optimized parts for this task from 10 years ago, when everything was purpose driven & had to be built from scratch.  Lions in those days evolved the equivalent of an IOT board out of a PIC18f14k50 & SI4421.  It used a milliamp at most when transmitting, & 3.3V.  The power consumption was so low by today's standards, it could run on some NiMH batteries & very cheap solar panels.   Lions wouldn't use Lithium batteries for this task because of the daily cycling.
    A small armada of these boards was built 10 years ago for transmitting heading from copters.  Today, they would be prized for their remote sensing ability.  They could be reworked for transmitting temperature.  The home router would have a board for receiving the packets.
    There isn't enough room to display the outdoor  temperature on a wall, but a web page could show it.  The temperature display could also receive packets & alternate between the indoor & outdoor temperatures.  There's no need to measure anything but temperature in Calif*.
  • Wishlist
    lion mclionhead07/28/2019 at 00:31 0 comments
    A lot hotter since the thermometer was installed. Lions have debated adding an exterior thermometer, a seconds display, & temperature logging.
    The seconds display is the least likely.  It would manely make it easier to wake up as close before the alarm as possible, but it would add a lot more blinking & it would be hard to see.
    All enhancements to the thermometer point to a mesh network.  The lion kingdom has a supply of XBees, but they use a lot of power.  Temperature logging for the indoor thermometer would have unlimited power.  Temperature logging outside would require solar power.
  • Clock documentation
    lion mclionhead04/04/2019 at 16:30 0 comments
    A year without commuting allowed the clock interface to never be used.  With the return to commuting, the lion kingdom had manely forgotten how to set the alarm.  It was time to document the control.  This is the last Yamaha remote the lion kingdom will ever have & it arrived 20 years ago with a stereo that's long gone.  The next remote once this one is lost will be completely different.
View all 17 project logs
seilerjacinda925 wrote 11/19/2019 at 16:08 point
Hi
Nice to meet you after viewing your profile i am Jacinda, from (jakarta) indonesia,
i have a project discussion with you please email me on: (jacinda.seiler@yahoo.com)
