![](https://cdn.hackaday.io/images/7499661665364831057.jpg)
![](https://cdn.hackaday.io/images/7822191665365281939.jpg)
The humidifier chewed up the wax paper, so it was time
![](https://cdn.hackaday.io/images/8152331665364865140.jpg)
To upgrade most of the weather wall to LCD panel diffuser. Sadly, it's not as diffuse as wax paper.
![](https://cdn.hackaday.io/images/5066531665364970533.jpg)
Heroineclock had to be cleaned of many critters.
![](https://cdn.hackaday.io/images/7016121665365065268.jpg)
Outside thermometer got HP panel diffuser. Heroineclock II got Dell diffuser which was decidedly less diffuse. Inside thermometer remaned wax paper, since it's held up better.
![](https://cdn.hackaday.io/images/1960591665365193349.jpg)
The heroineclock icons remaned wax paper since they're covered. Wax paper definitely degrades if it's exposed. Heroineclock I lasted 15 years with enclosed wax paper.
Future directions are going to have to be white PLA for the segments & diffusers. The oil based paint of the past is no longer sold. The diffusers aren't doing the business. The segments might have to be 1" deep.
