A lot hotter since the thermometer was installed. Lions have debated adding an exterior thermometer, a seconds display, & temperature logging.
The seconds display is the least likely. It would manely make it easier to wake up as close before the alarm as possible, but it would add a lot more blinking & it would be hard to see.
All enhancements to the thermometer point to a mesh network. The lion kingdom has a supply of XBees, but they use a lot of power. Temperature logging for the indoor thermometer would have unlimited power. Temperature logging outside would require solar power.
