[netmgr], who has similar hardware, realized why I was having trouble with the humidity field. It's not just one field, it's three separate fields that affect humidity! I believe they are two coefficients (I'll call them a and b), and a value. The dummy coefficients I had been sending had resulted in a nonlinear response to changes in value.
Armed with that knowledge, I started adjusting the other values as well. Plugged in a=b=100, sent a range of inputs to the value field, and plotted a (linear, this time) regression in a spreadsheet. Result:
Humidity is expressed as 500 * (161*percent + 1234) / 1983.
It may not seem like much, but it was the last "stumper"!
On my box I have a high humidity calibration and a low humidity calibration with values of 2981 and 811, respectively. I'm certain these are not fixed values, but might be good values to plug in when in doubt.
