I hope @oshpark will not mind abusing their motto for the PCBs not made by them, but the color is a bit similar.
I asked friend of mine to produce a few boards for me, as I know he is making some PCBs for himself, occasionally. He agreed and asked me what color of soldermask I want - I didn't care much, answering - "I don't know, let it be pink.". - "Say no more."
Searching for proper shade of the pink color.
Already drilled and etched PCB is covered by pink soldermask
White on pink, nice combo
Separated forever
And detail to my little PCBs
One PCB populated
Bottom side
The red and black wires are for powering the board during development.
LCD works!
So far so good, now I'm going to transcribe the sunrise/sunset detection algorithms, as well as reverse sunrise equation for use with the MCU, do some minor tasks, like user interface and logging - and LLG is done!
It looks great, I also plan to make a pink solder mask PCB. How do you adjust the color? Are there detailed steps?
Do you know what material the soldermask is? Not necessarily the pink, beautiful as it is, but just what kind of paint or whatever it is?
I'm going to try milling some PCBs and wonder about adding a soldermask to them.
It is classic two part solder mask (with hardener too), bought locally from here http://www.britrade.sk/sk/50-1-1/materialy-pre-elektrografiku/nepajive-masky There are links to datasheets, where you can find a lot of Czech text with some english names of the products, like
CAWN1290 Imagecure XV501T-4 Gloss Screen Dark Green Resist
CAWN1292 Imagecure XV501T-4 Screen Clear Hardener
etc.
On ebay you can find some one-part solder mask substances, like https://www.ebay.com/itm/10ml-PCB-UV-Curable-Solder-Mask-Fepairing-Paint-CSBD/232610214495 or dry film solder masks https://www.ebay.com/itm/Dry-film-solder-mask-Dynamask-5000-0-3m-x-1m-/282595757649 but those do not have such as mechanical/thermal resistance as standard two part resist.
these are so pretty!
Pretty! Next time add some glitter!
We need a script that randomly adds vias to simulate glitter...
woaaaaaah. you're making me jealous over here :D
