Perfect pink PCBs
A project log for Light level geolocator
If you have a lot of time, you can decide your position on Earth just using watches and eyes. Or RTC and LDR.
jaromirsukubajaromir.sukuba 01/02/2018 at 18:467 Comments
I hope @oshpark will not mind abusing their motto for the PCBs not made by them, but the color is a bit similar.
I asked friend of mine to produce a few boards for me, as I know he is making some PCBs for himself, occasionally. He agreed and asked me what color of soldermask I want - I didn't care much, answering - "I don't know, let it be pink.". - "Say no more."
Searching for proper shade of the pink color.
Here it is:
Already drilled and etched PCB is covered by pink soldermask
Soldermask etched away
White on pink, nice combo
Separated forever
And detail to my little PCBs
One PCB populated
Bottom side
The red and black wires are for powering the board during development.
LCD works!
So far so good, now I'm going to transcribe the sunrise/sunset detection algorithms, as well as reverse sunrise equation for use with the MCU, do some minor tasks, like user interface and logging - and LLG is done!
廣島秋澤 wrote 07/23/2020 at 13:12 point
It looks great, I also plan to make a pink solder mask PCB. How do you adjust the color? Are there detailed steps?
Ted Yapo wrote 01/18/2018 at 21:32 point
Do you know what material the soldermask is?  Not necessarily the pink, beautiful as it is, but just what kind of paint or whatever it is?
I'm going to try milling some PCBs and wonder about adding a soldermask to them.
jaromir.sukuba wrote 01/19/2018 at 07:57 point
It is classic two part solder mask (with hardener too), bought locally from here http://www.britrade.sk/sk/50-1-1/materialy-pre-elektrografiku/nepajive-masky There are links to datasheets, where you can find a lot of Czech text with some english names of the products, like
CAWN1290 Imagecure XV501T-4 Gloss Screen Dark Green Resist
CAWN1292 Imagecure XV501T-4 Screen Clear Hardener
etc.
On ebay you can find some one-part solder mask substances, like https://www.ebay.com/itm/10ml-PCB-UV-Curable-Solder-Mask-Fepairing-Paint-CSBD/232610214495 or dry film solder masks https://www.ebay.com/itm/Dry-film-solder-mask-Dynamask-5000-0-3m-x-1m-/282595757649 but those do not have such as mechanical/thermal resistance as standard two part resist.
Sophi Kravitz wrote 01/03/2018 at 12:26 point
these are so pretty!
deʃhipu wrote 01/03/2018 at 09:45 point
Pretty! Next time add some glitter!
Ted Yapo wrote 01/03/2018 at 13:03 point
We need a script that randomly adds vias to simulate glitter...
davedarko wrote 01/03/2018 at 09:30 point
woaaaaaah. you're making me jealous over here :D
