Homebrew ternary computer
TRIADOR: The only ternary computer made for real in the past 50 years.
Public Chat
Many claimed to build a ternary computer, however nobody (to the best of my knowledge) completed the project. TRIADOR project makes no empty promises!
In this project we are trying to build a very simple but functional 3-trit balanced ternary computer. The only building block allowed is a ternary multiplexer based on DG403 analog switches.
        Description of the ternary computer TRIADOR
  General purpose
     registers
 trits 2 1 0  (a trit can take -1,0,+1 values)
    R1│ │ │ │ \
      ├─┼─┼─┤ |                              Program memory
    R2│ │ │ │ |                            trits 4 3 2 1 0
      ├─┼─┼─┤ |-- main set                      ┌─┬─┬─┬─┬─┐
    R3│ │ │ │ |   of registers           a  -364│ │ │ │ │ │
      ├─┼─┼─┤ |                          d      ├─┼─┼─┼─┼─┤
    R4│ │ │ │ /                          d  -363│ │ │ │ │ │
      ├─┼─┼─┤                            r      ├─┼─┼─┼─┼─┤
    R5│ │ │ │ \                          e  -362│ │ │ │ │ │
      ├─┼─┼─┤ |                          s      ├─┼─┼─┼─┼─┤
    R6│ │ │ │ |                          s      : : : : : :
    R7│ │ │ │ |                              -1 │ │ │ │ │ │
    R8│ │ │ │ |                               0 │ │ │ │ │ │
      ├─┼─┼─┤ |-- extra registers               ├─┼─┼─┼─┼─┤
    R9│ │ │ │ |                              +1 │ │ │ │ │ │
   R10│ │ │ │ |                                 : : : : : :
   R11│ │ │ │ |                             +363│ │ │ │ │ │
   R12│ │ │ │ /                             +364│ │ │ │ │ │
   R13│ │ │ │ Special register,
      └─┴─┴─┘ specifies memory segment for JP ttt
   PC │ │ │ │ │ │ │ program counter register (-364..+364)
    C │ │ borrow/carry flag (+1 borrow, -1 carry)
  Every 3-trit register can take values from -13 to +13:
  t2*9 + t1*3 + t0
  where t0,t1,t2 - trits (-1,0,+1)
                 TRIADOR instruction set
  (for lisibility we use N,O,P instead of -1,0,+1)
  │op code│mnemonic│ description                           │
  │ NNttt │ EX ttt │ extension commands (work in progress) │
  │ NOttt │ JP ttt │ unconditional jump to R13*27+ttt      │
  │ NPttt │ SK ttt │ conditional skips of the next command │
  │ ONttt │ OP ttt │ tritwise unary operation over R1      │
  │ OOttt │ RR ttt │ copying between registers             │
  │ OPttt │ R1 ttt │ write ttt to the register R1          │
  │ PNttt │ R2 ttt │ write ttt to the register R2          │
  │ POttt │ R3 ttt │ write ttt to the register R3          │
  │ PPttt │ R4 ttt │ write ttt to the register R4          │
  Additional comments:
  - ttt means a 3-trit number with values
    from NNN (-13) to PPP (+13)
  - RR ttt instruction copies a register to/from R1 or performs
    an increment/decrement over R1
    OONNN — copy R1 to R13
    OONNO — copy R1 to R12
    OONNP — copy R1 to R11
    OONON — copy R1 to R10
    OONOO — copy R1 to R9
 OONOP...
ternary.vhd
Ternary VHDL package v1.0
x-vhdl - 7.30 kB - 07/06/2018 at 09:18
Download
ternary_circ.zip
Archive with TRIADOR simulation for Logisim v2.7.1 and also couple TXT files with some details from Shaos
Zip Archive - 49.99 kB - 06/23/2018 at 04:32
Download
TRIADOR.TXT
Specification of ternary computer TRIADOR (DOS encoding with pseudographics)
plain - 7.88 kB - 12/17/2017 at 23:58
Download
  • 600 × dg403dy Switches and Multiplexers / Analog Switches and Multiplexers
  • Ternary computer program emulator
    Dmitry V. Sokolov04/04/2020 at 13:06 0 comments
    To ease the debugging phase, here is an emulator for the ternary programs:
    https://github.com/ssloy/triador
    A very simple sample program that computes R2+R3 and stores the results back in R3:
    R1 NNN # N.B. the memory is not guaranteed to be initialized
    RR NNN # initialize R13 with -13, this chooses segment NNN for jumps
    R2 ONP # write -2 to R2            ┌─────────────────────────────────┐
    R3 PPP # write 13 to R3            │ This program computes R2+R3,    │
    RR OPO # copy R3 to R1 <─┐         │ the result is stored in R3.     │
    SK NPO # skip if R2!=0   │         │ Here is a C++ world equavalent: │
    JP PNO # R2==0, terminate│ ────┐   │                                 │
    SK PNP # skip if R2>0    │     │   │      int R2 = -2;               │
    RR OON # R1--            │     │   │      int R3 = 13;               │
    SK PNN # skip if R2<0    │     │   │      while (R2!=0) {            │
    RR OOP # R1++            │     │   │          int R1 = R3;           │
    RR ONO # copy R1 to R3   │     │   │          if (R2>0) R1++;        │
    RR OPN # copy R2 to R1   │     │   │          if (R2<0) R1--;        │
    SK PNP # skip if R2>0    │     │   │          R3 = R1;               │
    RR OOP # R1++            │     │   │          R1 = R2;               │
    SK PNN # skip if R2<0    │     │   │          if (R2>0) R1--;        │
    RR OON # R1--            │     │   │          if (R2<0) R1++;        │
    RR ONP # copy R1 to R2   │     │   │          R2 = R1;               │
    JP NOO # jump here ──────┘     │   │      }                          │
    EX PPP # halt and catch fire <─┘   └─────────────────────────────────┘
  • Homebrew ternary mini-series (s1e5): random-access memory board
    Dmitry V. Sokolov04/04/2020 at 13:04 0 comments
    Check for the subtitles if you do not speak russian.
  • Homebrew ternary mini-series (s1e4): memory cell
    Dmitry V. Sokolov04/04/2020 at 13:03 0 comments
  • Homebrew ternary mini-series (s1e3): multiplexers
    Dmitry V. Sokolov04/04/2020 at 13:02 0 comments
  • Homebrew ternary mini-series (s1e2): balanced ternary basics
    Dmitry V. Sokolov03/31/2020 at 09:10 0 comments
  • Homebrew ternary mini-series (s1e1): IO card
    Dmitry V. Sokolov03/31/2020 at 09:09 0 comments
  • TRIADOR ALU
    Dmitry V. Sokolov07/10/2018 at 19:39 0 comments
    Back to the true ternary triador implementation. The ALU will look like this:
    Compare it to the overall schematics of the triador in the project details. All input signals are shown on the left of the boxes, all output signals are on the right. The ALU consists of 5 slices (one per operation) plus one trit memory cell for the borrow/carry flag. This flag won't be accessible outside of the ALU, its value is set by the RR slice, and is read by the SK slice only.
    Just to give you an idea of what the boxes look inside, here is the OP box (tritwise unary operation over R1 register):
  • Ternary counter on VHDL
    SHAOS07/08/2018 at 09:26 2 comments
    I just literally copied this ternary counter design from 2011 into VHDL:
    This is VHDL source code (only 3 trits were used):
    library IEEE;
    use IEEE.STD_LOGIC_1164.ALL;
    use ternary.all;
    entity main is
        Port ( clk : in bit;
               res : in bit;
               a : in FakeTrit;
               b : in FakeTrit;
               c : in FakeTrit;
               s1 : out FakeTrit;
               s2 : out FakeTrit;
               s3 : out FakeTrit;
               led : out bit);
    end main;
    architecture Behavioral of main is
    signal a1,b1,c1,ss0,ss1,ss2,ss3,ss4 : FakeTrit;
    signal pclk,pclk1,nclk,nclk1,res0,res1,m1,m2,m3,m4,h1,h2,h3,h4,g1,g2,g3 : FakeTrit;
    signal tmp_clk_std, tmp_iclk_std : STD_LOGIC;
    signal tmp_clk : BIT;
    COMPONENT Clock_Divider
    PORT(
    clk : IN std_logic;
    reset : IN std_logic;
    clock_out : OUT std_logic
    END COMPONENT;
    COMPONENT Half_Adder
    Port ( a : in FakeTrit;
           b : in FakeTrit;
           s : out FakeTrit;
           c : out FakeTrit
    END COMPONENT;
    FUNCTION io_invert(T: FakeTrit) RETURN FakeTrit IS
    begin
                    case T is
                    when N =>
                            return P;
                    when O =>
                            return X;
                    when P =>
                            return N;
                    when others =>
                            return O;
                    end case;
    end;
    begin
    a1 <= io_invert(a);
    b1 <= io_invert(b);
    c1 <= io_invert(c);
    tmp_iclk_std <= to_stdulogic(clk);
    div1: Clock_Divider port map( clk => tmp_iclk_std, reset => '0', clock_out => tmp_clk_std );
    tmp_clk <= to_bit(tmp_clk_std);
    res0(0) <= '0';
    res0(1) <= res;
    res1 <= res0;
    clk1: ternary_clock port map( B_C => tmp_clk, T_C => ss0 );
    mux1: ternary_mux port map( T_S => ss0, T_N => O, T_O => O, T_P => P, T_C => pclk );
    mux2: ternary_mux port map( T_S => res1, T_N => pclk, T_O => N, T_P => N, T_C => pclk1 );
    mux3: ternary_mux port map( T_S => ss0, T_N => N, T_O => O, T_P => O, T_C => nclk );
    mux4: ternary_mux port map( T_S => res1, T_N => nclk, T_O => P, T_P => P, T_C => nclk1 );
    mem1: ternary_mem port map( T_S => pclk1, T_N => O, T_P => ss1, T_Q => m1 );
    ha1: Half_Adder port map( a => P, b => m1, s => h1, c => g1 );
    mem2: ternary_mem port map( T_S => nclk1, T_N => h1, T_P => O, T_Q => ss1 );
    mem3: ternary_mem port map( T_S => pclk1, T_N => O, T_P => ss2, T_Q => m2 );
    ha2: Half_Adder port map( a => g1, b => m2, s => h2, c => g2 );
    mem4: ternary_mem port map( T_S => nclk1, T_N => h2, T_P => O, T_Q => ss2 );
    mem5: ternary_mem port map( T_S => pclk1, T_N => O, T_P => ss3, T_Q => m3 );
    ha3: Half_Adder port map( a => g2, b => m3, s => h3, c => g3 );
    mem6: ternary_mem port map( T_S => nclk1, T_N => h3, T_P => O, T_Q => ss3 );
    s1 <= io_invert(ss1);
    s2 <= io_invert(ss2);
    s3 <= io_invert(ss3);
    led <= to_bit(tmp_clk_std);
    end Behavioral;
    Every trit in the counter takes 2 macrocells on CoolRunner-II, so technically CoolRunner-II chip XC2C256 with 256 macrocells may have up to 128-trit counter inside! This is pin assignments for XC2-XL board (a,b,c are not used here):
    NET "clk" LOC = "P38" | IOSTANDARD = LVTTL ;
    NET "res" LOC = "P143" | IOSTANDARD = LVTTL ;
    NET "a<0>"  LOC = "P140" | IOSTANDARD = LVTTL ;
    NET "a<1>"  LOC = "P142" | IOSTANDARD = LVTTL ;
    NET "b<0>"  LOC = "P138" | IOSTANDARD = LVTTL ;
    NET "b<1>"  LOC = "P139" | IOSTANDARD = LVTTL ;
    NET "c<0>"  LOC = "P136" | IOSTANDARD = LVTTL ;
    NET "c<1>"  LOC = "P137" | IOSTANDARD = LVTTL ;
    NET "s3<0>"  LOC = "P82" | IOSTANDARD = LVTTL ;
    NET "s3<1>"  LOC = "P83" | IOSTANDARD = LVTTL ;
    NET "s2<0>"  LOC = "P85" | IOSTANDARD = LVTTL ;
    NET "s2<1>"  LOC = "P86" | IOSTANDARD = LVTTL ;
    NET "s1<0>"  LOC = "P87" | IOSTANDARD = LVTTL ;
    NET "s1<1>"  LOC = "P88" | IOSTANDARD = LVTTL ;
    NET "led"  LOC = "P92" | IOSTANDARD = LVTTL ;
    and this is a video that proves that it's working on Xilinx CoolRunner-II ;)
  • Ternary VHDL package v1.0 is ready
    SHAOS07/06/2018 at 09:30 0 comments
    So now we have everything to build a ternary computer in binary CPLD (or FPGA)::
    https://cdn.hackaday.io/files/285791222723936/ternary.vhd
    Last pieces were just added:
    - procedure dmux:
            PROCEDURE dmux(signal T_S: IN FakeTrit;
                           signal T_C: IN FakeTrit;
                           signal T_N: OUT FakeTrit;
                           signal T_O: OUT FakeTrit;
                           signal T_P: OUT FakeTrit) IS
            begin
                    case T_S is
                    when N =>
                            T_N <= T_C;
                            T_O <= O;
                            T_P <= O;
                    when O =>
                            T_N <= O;
                            T_O <= T_C;
                            T_P <= O;
                    when P =>
                            T_N <= O;
                            T_O <= O;
                            T_P <= T_C;
                    when others =>
                            T_N <= X;
                            T_O <= X;
                            T_P <= X;
                    end case;
            end;
    - component ternary_mem:
    -- Entity ternary_mem
    USE ternary.ALL;
    ENTITY ternary_mem IS
            PORT (
                  T_S : IN FakeTrit;
                  T_N : IN FakeTrit;
                  T_P : IN FakeTrit;
                  T_Q : OUT FakeTrit
    END ternary_mem;
    ARCHITECTURE Behavioral OF ternary_mem IS
    BEGIN
        PROCESS (T_S)
        BEGIN
            IF (T_S(0) = '1') THEN
                T_Q <= T_P;
            ELSIF (T_S(1) = '1') THEN
                T_Q <= T_N;
            END IF;
        END PROCESS;
    END Behavioral;
      - component ternary_clock:
    -- Entity ternary_clock
    USE ternary.ALL;
    ENTITY ternary_clock IS
            PORT (
                  B_C : IN BIT;
                  T_C : OUT FakeTrit
    END ternary_clock;
    ARCHITECTURE Behavioral OF ternary_clock IS
    signal flag : bit;
    BEGIN
        PROCESS (B_C)
        BEGIN
            IF (B_C'event AND B_C = '1') THEN
                IF (flag = '0') THEN
                    flag <= '1';
                ELSE
                    flag <= '0';
                END IF;
            END IF;
            IF (B_C = '1' AND flag = '0') THEN
                T_C(0) <= '1';
            ELSE
                T_C(0) <= '0';
            END IF;
            IF (B_C = '1' AND flag = '1') THEN
                T_C(1) <= '1';
            ELSE
                T_C(1) <= '0';
            END IF;
        END PROCESS;
    END Behavioral;
    Last one turns binary clock into ternary sequence NOPONOPONOPO...
    Also I renamed some variable names and added additional components for mux and dmux ( just in case if somebody doesn't like them as functions ; )
  • Interfacing ternary and binary components
    SHAOS07/05/2018 at 04:15 0 comments
    Ok, now it is kind of proven that binary CPLD (or FPGA) may implement ternary logic, but how we can integrate it with "true" ternary components, especially when CPLD is 3.3V and TRIMUXes are -5V and +5V? Answer is DG403 chips may do the job:
    Because simplified ternary mutexes e12 and e21 can be easily implemented by DG403 integrated circuits:
    So we need to have ONE DG403 per every binary represented TRIT and it doesn't matter if it's input or output, but number of inputs should be multiple by 2 in order to use DG403 chips optimally.
    Also we can do similar interfacing for binary ROM or RAM that may also be required for complex ternary systems. For example we can do translation from triad (3 trits) to a byte the same way how it's already done in 3niti alpha simu1 ternary computer simulator on PIC16:
    ;Format of the triad:
    ;|7|6|5|4|3|2|1|0|
    ;|par|low|mid|high
    ;par (parity) is not yet used, so it's always 0 0 for now...
    tOOO    EQU    0x00 ; 0
    tNOO    EQU    0x01 ; -9
    tPOO    EQU    0x02 ; +9
    tONO    EQU    0x04 ; -3
    tNNO    EQU    0x05 ; -12
    tPNO    EQU    0x06 ; +6
    tOPO    EQU    0x08 ; +3
    tNPO    EQU    0x09 ; -6
    tPPO    EQU    0x0A ; +12
    tOON    EQU    0x10 ; -1
    tNON    EQU    0x11 ; -10
    tPON    EQU    0x12 ; +8
    tONN    EQU    0x14 ; -4
    tNNN    EQU    0x15 ; -13
    tPNN    EQU    0x16 ; +5
    tOPN    EQU    0x18 ; +2
    tNPN    EQU    0x19 ; -7
    tPPN    EQU    0x1A ; +11
    tOOP    EQU    0x20 ; +1
    tNOP    EQU    0x21 ; -8
    tPOP    EQU    0x22 ; +10
    tONP    EQU    0x24 ; -2
    tNNP    EQU    0x25 ; -11
    tPNP    EQU    0x26 ; +7
    tOPP    EQU    0x28 ; +4
    tNPP    EQU    0x29 ; -5
    tPPP    EQU    0x2A ; +13
    As you can see we directly translate triad to byte and vice versa for data, but we can do the same for address - lower 3 trit of address can address the same 48 bytes (so instead of 27 triad one page will occupy 48 bytes of binary memory). Higher trits of address may or may not have similar translation.
    Also we can have a special CPLD that converts ternary address to binary address optimally (without gaps and holes as above). Below you can see calculations for mostly used memory sizes:
    2KB = 11-bit address = 6 trits (729 ternary cells - 28% used);
    8KB = 13-bit address = 8 trits (6,561 ternary cells - 63% used);
    32KB = 15-bit address = 9 trits (19,683 ternary cells - 48% used);
    64KB = 16-bit address = 10 trits (59,049 ternary cells - 71% used);
    128KB = 17-bit address = the same 10 trits (59,049 ternary cells - 45% used);
    256KB = 18-bit address = 11 trits (177,147 ternary cells - 67% used);
    512KB = 19-bit address = the same 11 trits (177,147 ternary cells - almost 34% used);
    1MB = 20-bit address = 12 trits (531,441 ternary cells - almost 51% used).
    As you can see we have better usage of binary memory in ternary computer system when it's 64KB addressed by 10 trits and this approach will use 71% of memory space.
    In case of TRIADOR we have 6-trit address for program memory - it has addresses from -364 to +364 and each read-only memory cell should have 5-trit value - to simplify things in my Logisim model I addressed 2K binary ROM directly when every TRIT of ternary address is converted to 2 BITS of binary address, but in this case it has to be 12 bits total, but we have only 11 (2^11=2048) - my idea was to allow user to use ternary addresses from ONNNNN to PPPPPP only (it is 66% of all 6-trit address space and should be more than enough for start) and we need to convert 1-byte data to 5-trit program word by another smaller ROM (or CPLD):
        <comp lib="4" loc="(850,300)" name="ROM">
          <a name="dataWidth" val="10"/>
          <a name="contents">addr/data: 8 10
    0 1 6 4 5 1a 18 19
    12 10 11 16 14 15 6a 68
    69 62 60 61 66 64 65 4a
    48 49 42 40 41 46 44 45
    5a 58 59 52 50 51 56 54
    55 1aa 1a8 1a9 1a2 1a0 1a1 1a6
    1a4 1a5 18a 188 189 182 180 181
    186 184 185 19a 198 199 192 190
    191 196 194 195 12a 128 129 122
    120 121 126 124 125 10a 108 109
    102 100 101 106 104 105 11a 118
    119 112 110 111 116 114 115 16a
    168 169 162 160 161 166 164 165
    14a 148 149 142 140 141 146 144
    145 15a 158 159 152 150 151 156
    154 155 13*0 2aa 2a8 2a9 2a2 2a0
    2a1 2a6 2a4 2a5 28a 288 289 282
    280 281 286 284 285 29a...
View all 24 project logs
Farooq Karimi Zadeh wrote 03/06/2021 at 09:02 point
Hello. Your project seems interesting but dg403 is so expensive and is not easy to find.
I don't know much about Electronics but perhaps they can be replaced with 4016? 300 of them have enough analogue switches and the price will be reduced a LOT.
SHAOS wrote 05/30/2023 at 03:38 point
No. 4016 uses the same power for logic and analog parts, but DG403 uses different power pins for logic and analog so we can play with it shifting thresholds to achieve desirable results: http://shaos.net/blog/2010/08/ternary-multiplexer-selector.html
alice crush wrote 10/06/2020 at 07:41 point
I am very impressed by your project. I espescialy liked your io board.
I setout to write multiply, I finished but I am doubtfull that it
would work.  I really wanted call/return, and unconditional skip.
please put them in your cpu.  I am also suprised to find no a in your
alu.  Atleast put in add.  And another glaring whole is the inability
to write to memory.  Just a simple load and store... though a stack
wants to index memory by a register.  So my wishlist is call/return
add and write to memory. in detail...
add  r1,rn      ; r1= r1+rn
skip            ; always
call ttt        ; the usual, like jp, saving the return address on
                ; the stack
return          ; pc= top of stack, drop the return address from the stack
RM ttt,rn       ; memory[r13*27+ttt]= rn
RIdxM ttt,r1,rn ; memory[r13*27+ttt+r1]= rn
simple but addequit. I would implment them in the order listed.  Do
you have any thoughts?  Please let me know.  Oh a halt instruction and
a way to ring a bell would be nice!  But adding to the list of features
is always easy.  :)  Whats hard is leaving them out!
what folllows is my first atempt at a muliply..... and a joke...
-360: oppoo R1 POO / r1=9
-359: oppnn R2 PNN ; r2=5
-358: noooo jp ooo ; trimul
----: ;;; result in r5,6= 45
-357: oppon R1 PON ; r1=8
-356: oppn0 R2 PNO ; r2=6
-355: noooo jp ooo ; trimul
====: ;;; result in r5,6= 42 more or less
-354: nottt jp halt ; jp .
----: ; trimul
000: ooopp RR r4,r1
001: oooon dec r1
002: npopp skg r1
003: xxxxx ret
004: nopoo jp triadd
005: nooop jp oop ; again...
006: ; end
----: ; triadd result r5,6
009: ooonp RR r1,r2
010: oooon dec r1
011: npopp skg r1
012: nopnn jp pnn;ret
013: oopop RR r5,r1
014: oopno RR r1,r6
014: oooop inc r1
015: oopoo RR r6,r1
016: npoon skc -1
     npppp skip r4>0
017: nopop JP pop
018: oopnn RR r1,r5
019: oooop inc r1
020: oopop RR r5,r1
021: nopop JP pop
alice crush wrote 09/19/2020 at 23:21 point
your alu doesnt do addition?
xor wrote 08/01/2018 at 11:29 point
better way is 0 1 *
please read book evolution algorithm goldberd
SHAOS wrote 08/02/2018 at 00:58 point
no it is not :)
fabian wrote 08/04/2018 at 13:13 point
this is not trouble caligraphy ,
read abou genetic algorithm
SHAOS wrote 05/30/2023 at 03:39 point
I used genetic algorithms in 90s...
