Soldered TX to TX (It looks like there is a buffer after TX on the midi board), 5v to 5v, ground to ground, plugged in, and hey, the light flashes (YAY!) but software doesn't do anything. I guess it couldn't be that easy.
Looks like the CTK-481 has midi out. That is just one number bigger. Maybe it is using the same circuitry?
I guess I'll probably need to invert the signal.
stephengeorgewest
Tina Belmont
glgorman
recursinging
Johan Berglund
Hi, thanks for this mod! Wiring with only resistors, transistor and DIN socket: https://github.com/KevinSalmon/Casio-CTK-480-MIDI
