Hex Keypad Entry
A project log for Boxer-1 TTL Computer
An 8-bit TTL computer with 8 bits of address space.
boxerbombBoxerbomb • 12/29/2017 at 18:09•0 Comments
I have created a hex Keypad entry system using Arduino. The Arduino decodes the keypad with the matrix library and provides a binary output. The keypad currently isn't tri-state but I will add a fix either in the code or by adding a 74ls245. I use it just for easy testing of the system but will be later used by the user with clock interrupts.
