This project is a collaboration with Younjin Song, Sairanjith Thalanki, and Andrew Ge. It was supported by Robotics@Berkeley as part of their annual DXM Robotics Competition.
App
- Users name each platform in the app depending on the item it is tracking
- To setup an item, Re.Stock takes a calibration reading of the platform while empty. Users then place on the item and specify how full it is
- Users adjust the percent of the item left at which they receive a notification. Setting the level higher can account for the weight of the item's packaging
- The app compares each reading to the empty platform calibration reading so it can ignore data taken when the item is not on the platform
Hardware
- Box and platforms built from birch plywood, finished with spray lacquer
- Each platform is attached only to a load cell underneath
- Load cells secured to wood using tee nuts and machine screws
Electronics
- Each load cell is connected to a HX711 amplifier board, which reads the voltage signal from the cell and converts it to a digital signal read by an Arduino
- Amplifiers receive a 5V power supply, a shared ground, and a clock signal from the Arduino
- Arduino takes periodic readings from the amplifiers and passes on the data to the ESP8266 WiFi Module
- Entire system is powered off a 5V power supply connected to the Arduino
Programming
- Data sent to ESP is passed on to a database hosted online using PHP
- App uses HTML parser to pull data from the webpage
Trond B.
lukasz.iwaszkiewicz
