Magical box for Resuming 3D Prints automatically.
Resumer 3D is on Kickstarter now : https://kck.st/2xQmZYK
Resumer 3D launched a project on kickstarter, it is online: https://kck.st/2xQmZYK Allows a print to be recovered after certain types of failure. Join in our Facebook group: https://www.facebook.com/groups/247271792709370/
pipossible causes: tangle/filament break; nozzle jam; power outage.
Compatibility:Resumer 3D is compatible with marlin firmware based 3D printer, printing with SD card. Monitor: With this monitor box we can rescue a failed 3D print job automatically by press the OK button . Becuase of that it not just can detect the power off,but also can record every layer 's information (through USB cable) while SD printing. Thanks for Hackaday!!!
Where Can I buy Resumer 3D if I missed Kickstarter?
eBay: https://www.ebay.com/itm/132757128584
Amazon.co.uk: https://amzn.to/2NR1OZY
Amazon.de: https://amzn.to/2wMKlv8
Amazon.fr: https://amzn.to/2MPb58g
Amazon.it: https://amzn.to/2MNvNWh
Amazon.es: https://amzn.to/2NTNEHE
How does it work?
 Resumer 3D simulate the way of how 3D printer software works, sending out and receive G-code by USB port. By this way, when your printer is working, Resumer 3D will monitor the status of the 3D printer, record the printing data in real-time. Furthermore, there is a super capacitor built in Resumer 3D, even if the power shuts off unexpectedly, the super capacitor will keep Resumer 3D alive and store your printing data solidly. When you turn on 3D printer, as Resumer 3D has stored all the printed data, it can resume the prints fromany printed layer automatically. Resumer 3D makes everything easier.
        At beginning, many people are doubt that why Resumer 3D is so compatible as it can work with different 3D printers. Thanks to my team, we have tried our best to insert different USB drivers of different 3D printers; furthermore, as how Repetier-Host and Cura control 3D printer, Resumer 3D  use the same way to communicate with 3D printer and control it by G-code command.
Easy to use!
You simply connect Resumer 3D to your 3D printer via USB cable, leave it alone. No headache of editing G-code, no afraid of technical problems when you choose Rasperry Pi.
       Although we have tested almost all the 3D printers that we can find in the market, we may miss some of them. If you find that your 3D printer is not compatible with Resumer 3D, please get in touch with us, our technical team will upgrade the firmware for you, please click here you can download the latest firmware. Thanks for your support.
https://github.com/Resumer3d/Resumer3D-module
v1.1.3.bin
octet-stream - 65.39 kB - 10/30/2018 at 05:43
Download
boxTool.zip
for upgrading the resumer 3d box firmware and settings.
x-zip-compressed - 10.78 kB - 04/18/2018 at 09:34
Download
This is the screen capture while run Printer_check.exe
Portable Network Graphics (PNG) - 51.81 kB - 04/17/2018 at 11:38
Preview
Printer_check.zip
Use this software tool (for Windows) to check whether your 3d printer can be worked with our resumer3D box. check 2 points: gcode command(marlin is ok) and which the usb driver chip your printer use.
x-zip-compressed - 11.45 kB - 04/17/2018 at 03:15
Download
View all 26 project logs
  • 1
    Thanks @Akos Wonerth
View all instructions
Kaushik wrote 08/04/2020 at 10:10 point
Hi, I wish to purchase this amazing product. From where can i get my hands on one of these?
Thomas wrote 05/28/2019 at 11:54 point
Hi, do you finally support Octoprint and printing through USB instead of SD card only? I am planning to purchase it but i am using Octoprint to manage my printer from network or remotelly and i am printing through octoprint instead of sd card.
Michael H. wrote 09/18/2018 at 18:05 point
I tried to update the FW to 1.1.1 but stuck in boot loader mode. How can I flash the boot loader again?
robert wrote 10/10/2018 at 02:03 point
the bootloader will not be overwrited, the problem is from FW1.1.1, please update to 1.1.2 or 1.1.0
ekaggrat singh kalsi wrote 09/11/2018 at 02:34 point
the ebay link has no option to ship to china. you are in shenzen and no shipping to china mainland ! why? is there any other option to buy from within china? taoboa?
robert wrote 09/11/2018 at 03:58 point
Hi friend,
I am sorry for that, currently we do not sell this product in China online, if you need one, you can get in touch with me via wechat, my id is: foxtery      Have a good day!
Mike wrote 08/23/2018 at 19:58 point
Because of personal issue i mist the kickstarter. Is there a way to order this else where.
robert wrote 09/05/2018 at 11:49 point
Hi Mike, you can get it from ebay: https://www.ebay.com/itm/132757128584
gehtdienixo wrote 06/19/2018 at 05:03 point
Where i can get an resumer with shipping to Germany? Willl IT Work anytime with octoprint?
robert wrote 06/22/2018 at 11:51 point
Hi gehtdienixo, Thanks for support our project! now the shell mould is opening, and the resumer3D will be on amazon and ebay for sale in the middle of july. currently Resumer 3D could not work together with Octprint, however, our team is testing and updating the firmware, once it`s finished, they can work together.
gehtdienixo wrote 06/22/2018 at 13:08 point
Did you ship worldwide? When yes i wil buy one if it is released ;). And how much will be the final price?
robert wrote 06/25/2018 at 02:32 point
Hi friend, you can order one on kickstarter: https://www.kickstarter.com/projects/resumer3d/resumer-3d-resume-your-interrupted-3d-prints-autom?ref=creator_nav
The final price on Amazon.de will be 28Euro-30Euro. So it is better for you to buy it on Kickstarter :)
john wrote 06/10/2018 at 11:39 point
1) Will this work with control boards running smoothieware? It is set to Marlin in my slicer so I would expect it will work.
2) Will this work when printing Octoprint on a RasPi.
3) running the Printer_Check_Tool I don't see anything coming back from the printer except for temp readings. Once the print actually starts there is nothing.
robert wrote 06/10/2018 at 12:12 point
Hi john, Thanks! 1) which USB driver chip of your motherboard ?resumer3d support: PL2303/CP2102/FT232/CH340/CH341/ Atmega16u2 /atmega32u2
2) I am sorry that currently resumer3d can not work with octoprint now.
john wrote 06/10/2018 at 12:18 point
ACPI\PNP0501\1_0
USB\VID_1D50&PID_6015&MI_00\7&b3f53ea&0&0000_0
The controller board is a Panucatt Azteeg X5 mini.
robert wrote 06/10/2018 at 14:26 point
Hi john, we have not test on Panucatt Azteeg X5 mini, and maybe need to add this usb driver to resumer3d. so we will need to buy this board to debug. and will keep you informed when It works OK.
robert wrote 06/25/2018 at 02:36 point
Hi John,
1) Resumer 3D only works on marlin based 3D printer.
2) Resumer 3d will work with Octoprint, my team is upgrading the firmware. Once it`s finished. it will work.
3) if you can send me the log to resumer3d@gmail.com? We will check it for you.
odin rios wrote 06/08/2018 at 13:28 point
hi guys
first great idea! im current following the project and i wanna pledge on kickstarer but i have a question : there is two options one for $21 for the hackaday.io and other for $24  how they work?  and im interest in get at least 3 units , please can you guys contact me how to to it ?. also is see on the list of compatible printers some missing brands , i have 4 different printer all different brands including a FLSUN i3 + ,  a CTC Dual XY core, a Lamchua XY core printer and a SUNHOKEY i3 with MKS v1.4 board if you guys need to test the device on any of this brands im willing to help. i located in usa ,New York. i hope ear from you guys soon, best regards odin.
robert wrote 06/12/2018 at 07:07 point
Thank you friend :) If you like this project, is it possible for you to share this project with your 3D printer friends? That will help us a lot. Thank you very much!
robert wrote 05/07/2018 at 14:46 point
Hi Trent Steele, thanks a lot ! Resumer3D will be on  kickstarter this month ,we will keep you informed.
Trent Steele wrote 05/08/2018 at 12:03 point
Wow, I hate to even have to wait that long. I had a ruined print just recently that had been running for 2 days and stopped due to a Thermal Sensor Error. This product would have saved my print.
robert wrote 06/05/2018 at 12:10 point
Hi Trent, I am sorry for that we let you wait for a long time, goods news is that it is on kickstarter now: https://www.kickstarter.com/projects/resumer3d/resumer-3d-resume-your-interrupted-3d-prints-autom
Trent Steele wrote 05/08/2018 at 12:11 point
Count me in for beta testing!
robert wrote 05/09/2018 at 14:06 point
would you please tell me your email address? or you can send a email to resumer3d@gmail.com
Trent Steele wrote 05/07/2018 at 13:41 point
How do I get one of these Resumer3D units?
robert wrote 05/10/2018 at 06:04 point
Hi friend,
You can write an email to resumer3d@gmail.com, we will give you more details. How do you think that?
