Let’s add the second main piece (1x2)
It looks as a pair of connected main squares (let’s name them 1x1).
It speeds up construction.
it lets build stronger parts using brick lock.
It can strengthen the large flat faces and corner edges with longerons and spaces.
Printed sample:
A pretty strong hook for backpack:
Uploaded here 2x2-1x2-plate.stl
