Time for a much needed update. High Voltage coming together.
A project log for BUILD an ARCADE XY VECTOR MONITOR
I set out to build a working 13"-27" CRT Arcade XY Vector Monitor. UPDATE!!! 5" and 9" monitors too.
fredkonofredkono • 10/17/2014 at 14:45•3 Comments
Okay I have settled on a elegant and cheap solution to making the High Voltage.
If you want to follow a long you will need to buy one each of these items.
2SD2599 or equivalent Hot transistor. Most of the newer hot transistors will work. (I used one out of a 13" TV)
One of these SMPS.
http://www.ebay.com/itm/251389244815?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
This flyback is the one I settled on because it is cheap and available.
http://www.ebay.com/itm/400453658884?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
555 timer, A few fast switching diodes (UF4007), 2n2222, some resistors, capacitors and misc. Most stuff any good parts bin will have.
Some of you might ask why did you not use a WG6100 or Amplifone flyback. The answer is simply because it was cheaper to use the above components. The WG and Amplifone flybacks are $40 or so each (I even asked about price breaks). All the parts to build the version I made should be less than that to build with all new parts. I was thinking about designing a pcb with a SMPS for B+ when I found that the Chinese already built one for less than $10.
Stay tuned for lots of updates and in the mean time collect up some parts.
fredkono wrote 02/03/2015 at 03:16 • point
looks good. Just have to adjust for the different pin out.
charlton.rodda wrote 01/16/2015 at 01:11 • point
Would this one work? http://www.ebay.co.uk/itm/331275918794
charlton.rodda wrote 01/16/2015 at 00:38 • point
What characteristics am I looking for in the flyback? Unfortunately from here the shipping on that particular item costs more than the parts.
