Schematic of high voltage. I did not build the shut down circuit that is in the slotted box and added it just for reference in the schematic. I may add it at a later date, but as drawn it probably will not function right so leave it off if your going to build a prototype. If anyone has a place to host files and stuff for this project let me know and I will email all the files for you to host. Thanks
fredkono
https://db.tt/bGg8MYz
