1Step 1
If you want run the application on your PC :
1) Download the .zip project on github or the website of the project.
2) install Processing.
3) With Processing, add a library -> install : Opencv for Processing, ControlP5 and BezierSQLlite.
4) On Linux : install the Oracle'sJDK because the library is incompatible with OpenJDK and demands Oracle's JDK.
5) It's work ! You can run the application at ScanComponentPCB/application.linux64/ScanComponentPCB for exemple.
Christopher Sainsaulieu
